Oil seal help please
PostPosted: Fri Feb 10, 2012 10:15 am    Post subject: Oil seal help please Reply with quote
Hi all
Is there a seal that fits to replace this seal
Tav 9
# 38 part number 10-6061
It is the clutch push rod seal ( clutch basket side in main sharft )
Let me know ?
Cheers Trev
PostPosted: Fri Feb 10, 2012 12:28 pm    Post subject: Reply with quote
Can you take the seal out? It may have a nmber on it. Otherwise take it to a bearing/ seal supplier and they should be able to match it.
PostPosted: Fri Feb 10, 2012 2:58 pm    Post subject: Reply with quote
Seal size is
ID 8mm
OD 14mm
tall 5mm
Cheers Trev
PostPosted: Fri Feb 10, 2012 3:44 pm    Post subject: Reply with quote
Trev
Thats a standard size seal in UK. Local seal place should have one Smile
PostPosted: Sat Feb 11, 2012 1:32 am    Post subject: Reply with quote
Yes it is a normal size but
it needs to be a rod seal not a radial seal etc
Cheers Trev
tlracing
PostPosted: Mon Feb 20, 2012 1:50 pm    Post subject: Reply with quote
Try SIL in NZ:
http://sealau.public.neotek.co.nz/default.aspx
PostPosted: Tue Mar 20, 2012 9:27 pm    Post subject: Reply with quote
Got the seals now from these guys
http://www.bimota-parts.de/
Very helpful and a better seal then the stock item
Trev
