bimototo
Posted: Fri Mar 30, 2012 10:04 am Post subject: turning the key...... |
last night,
after 2month an half,
I turn the key of my db4 again.....
She's not completly assembly and at the moment the wiring is not completly wired,
but
almost everything works  _________________
Posted: Fri Mar 30, 2012 10:09 am Post subject: |
Result.....
Very gratifying when it all works......
Now get it finished and enjoy it  _________________ SB6 mk1 (project mega light, big bore)
bimototo
Posted: Fri Mar 30, 2012 10:16 am Post subject: |
I've this bike since 2001,
every year I make some "tuning" and every year is more light.......maybe I've reach 150kg with oil and fuel.......I'm really impatient to put she on a weigth meter (how is called in english?)
some picture soon!!!!! _________________
Posted: Fri Mar 30, 2012 5:20 pm Post subject: |
I think thats a good way of having a bike. Why change it every year when you can spend less money, loose none and keep your pride enjoy. Newer is nice but better is, well, better.  _________________ Pomps
bimototo
Posted: Fri Mar 30, 2012 5:32 pm Post subject: |
| Pompey wrote: |
I think thats a good way of having a bike. Why change it every year when you can spend less money, loose none and keep your pride enjoy. Newer is nice but better is, well, better.  |
mmm.....spend less......I would like to talking about  _________________
Posted: Fri Mar 30, 2012 6:49 pm Post subject: |
What ' tuning' has your db4 had this year bimototo?
Just ordered some je pistons and corrillo rods for mine, plus lightened clutch and flywheels, hopefully will get around to fitting them and following heads at the end of the year. |
bimototo
Posted: Fri Mar 30, 2012 8:25 pm Post subject: |
| vort28 wrote: |
so, this year I've redo completly the wiring,
redo the dash complement (I have a translogic), I've adapt the single seat monocoque.
and I've also build the exahust can support and the mirror support.
I've change mirror and rearlight (both with integrated turn signal) and reaction rod (titanium and carbonfiber).
finally, I've do the box for the oil vapor with silicon hose (what the name in english???).
already present:
light flywhell (1.2kg 0.8 is too much)
light clutch (everything)
racing radiator
single filter (no airbox)
complete exaust system (50mm hand made from a very famous artesan)
translogic microdash
refluxed and polished head and valves
frame and swingarm mirror polished (by myself)
evr clutch piston
pwc2 with fine tuning on a test desk (maybe is not the right translation)
rearset with regulation
light battery (racingbatteries.un)
ergal levers
doublebubbles windscreen
finally I've remove all the unuseful matters (screw, wire, support)
maybe I've forget something.....
for the next year........mmmh 4valvles????? _________________
Posted: Fri Mar 30, 2012 8:49 pm Post subject: |
| Quote: |
| I've do the box for the oil vapor with silicon hose (what the name in english???). |
Crank case oil breather I guess to a external filter?
| Quote: |
| pwc2 with fine tuning on a test desk (maybe is not the right translation) |
Dyno is the translation you are looking for.
I forgot yours was an IE.
Think we are about even on the chassis side, although I have replaced the wheels, and as many bolts possible with alloy or titanium, but still have the stock headers with the corse titanium can.
Hopefully this time next year I will be about the same as you with the engine.
Thought about putting a 848 motor in myself, but decided that would just cost to much and possible spoil the character of the bike. Went for the high comp pistons etc I will try to leave the mods alone after the engine and concentrate on one of the others. Hopefully.
Will have to get around to wieghing mine, as would like to get into the 150's wet also. |
bimototo
Posted: Fri Mar 30, 2012 9:15 pm Post subject: |
take care! the 848 maybe do not fin (rear cylinder us to hight!)
in my opinion hp us like money (never enough) but you're right, us a really short bike and tool much hp risk to make she too nervous.....
for me the right engine for a db4 chassis is the one of an St4, us enough to replace the flywheel
my idea us to buy an used st4 (there's a lot at a good price), switch the engine, and built a cafè racer with my engine and the st4 chassis  _________________
Posted: Fri Mar 30, 2012 10:40 pm Post subject: |
check out my 851 rebuild thread... I am doing exactly that with an st4s! _________________ Pomps
bimototo
Posted: Thu Apr 05, 2012 7:33 am Post subject: |
yesterday morning I push the button
all cable are connected and my baby have sing again
just some bodyworks left and we're ready to run and rumble!!!!! _________________
Posted: Thu Apr 05, 2012 7:34 am Post subject: |
whoo hoo.........excellent  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Apr 05, 2012 12:03 pm Post subject: |
good news!!
keep us updated. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
bimototo
Posted: Sun Jun 24, 2012 12:10 pm Post subject: |
uff.....it's like a neverending story, the is quite disassembled, first some problem on the bike the some problem to my elbow.....fuck... . _________________
