new member
flarkster
PostPosted: Wed May 06, 2009 6:17 pm    Post subject: new member Reply with quote
Hello All
I am a new member so please make allowances for my duff typing etc. I have a 1995 SB6 which has now done a biblical 1,600 miles from new. It is black and red and is totally standard and as new. has any one any info on the rear brake light switch or a possible replacement??
Admin
Site Admin
PostPosted: Thu May 07, 2009 1:44 am    Post subject: Re: new member Reply with quote
Not sure but isn't it a pressure switch banjo bolt? If so then it is probably the same as that used on Aprilia RS125s (amoung others) and should be pretty easy to source.
Keith
sapila racing
PostPosted: Thu May 07, 2009 11:26 am    Post subject: Reply with quote
Hi and welcome,
I also have an SB6 same colours as yours.
The original switch is useless and almost all of them fail. I replaced it with a brembo switch normally used on Ducatis.
It has the same thread etc but half the size and it doesn't fail.
