SB6 Caliper Bolts
SiBag
PostPosted: Fri Apr 27, 2012 10:13 am    Post subject: SB6 Caliper Bolts Reply with quote
Hi All,
Tarting up my SB6 and swapping some of the manky rusty bolts and washers for stainless steel items. (I may even spoil it and get some Ti)
Does any body know the size of the caliper bots, the ones that bolt the two halves of the caliper together.
Cheers,
Si..
Si...
PostPosted: Fri Apr 27, 2012 10:57 am    Post subject: Reply with quote
Well, funny you should ask...........
...here's one I prepared earlier Wink
M8 X 40mm (measured from underneath the head)
As you can see, they are Brembo shallow head bolts. Similar to Bimota shallow head bolts. If your thinking "stainless", I just turn a couple of mm of standard socket heads Wink
SiBag
PostPosted: Fri Apr 27, 2012 11:30 am    Post subject: Reply with quote
Cheers for that Oily,
I looked on the probolt site and they only list fairing bolts and nipples mmmmmm nipples.
I then looked at the Duc 916 listing on the off chance they use the same caliper. and yes they are M8 x 40.
All I have to do now is fins some cheep ones,
So stainless or Ti ??????
And so it begins....
Thanks,
Si...
PostPosted: Fri Apr 27, 2012 11:49 am    Post subject: Reply with quote
stainless ... Wink
PostPosted: Fri Apr 27, 2012 12:08 pm    Post subject: Reply with quote
Yes I know, Thast's what I told you
Thanks,
Deffo Stainless as Pompey said.
"and so it begins"? We know a thread named that don't we boys and girls Laughing
PostPosted: Fri Apr 27, 2012 12:53 pm    Post subject: Reply with quote
Low head allen bolt innit
So £7.50 for Stainless (you'll need 2 packs)
http://www.boltmeup.com/m8-x-40-stainless-low-head-allen-cap-bolts-x-4-pack-307-p.asp
SiBag
PostPosted: Fri Apr 27, 2012 12:59 pm    Post subject: Reply with quote
Thanks for that evil.
They are flogging them on evilblag for 3.55 (bargan), same company.
Thanks all..
Si...
PostPosted: Sat Apr 28, 2012 12:31 pm    Post subject: Reply with quote
[quote="oily"]
That's more like a novel than a thread Laughing
PostPosted: Sun Apr 29, 2012 2:28 am    Post subject: Reply with quote
Thanks EC. I've been searching for these low head stainless bolts for a while now. I could only find them in black steel but not SS.
I love this forum Wink
