GOODRIDGE brake line deals
PostPosted: Mon Jun 11, 2012 9:21 am    Post subject: Reply with quote
Stockcar, can you supply double banjo bolts with/without pressure switch ?
Is there a time limit for the order ? I am guessing if I want anything other than an SB6 you need the originals to copy ?
PostPosted: Mon Jun 11, 2012 6:53 pm    Post subject: Reply with quote
yes can happily supply banjo's of whatever variety seperately............
as for the time limit it will be guided to a degree by those that order but i dont idealy wnat it to drag for months........
any that we dont have a listing for can be sorted at a very favourable deal if you supply a pattern (this is on-going)
PostPosted: Mon Jun 11, 2012 6:54 pm    Post subject: Reply with quote
(3x sets RACE front) - OILY
(1x sets RACE front) - Bimsb6 - PAID
(1x sets RACE front) - MARTIN - PAID
(1x sets RACE front) - Mike Jennings
(1x sets RACE front) - Quackers
if you can update the list as you forward your details to the office please
PostPosted: Tue Jun 12, 2012 6:54 am    Post subject: Reply with quote
stockcar wrote:
(4x sets RACE front...1x rear) - OILY
PostPosted: Tue Jun 12, 2012 9:06 am    Post subject: Reply with quote
I am probably after ones for a vdue,DB4, SB8K and maybe a yb11 and a SB6.
I will also be going from normal m/cyl to radial which will need the top banjo rotating on all but the SB8k (currently radial anyway), what is the race set up config for the SB6
What do you need as a pattern ?
PostPosted: Tue Jun 12, 2012 10:57 am    Post subject: Reply with quote
How many questions Shocked
The only one I can answer is........SB6 race config is two straight lines from master cylinder to calliper Wink
PostPosted: Tue Jun 12, 2012 11:10 am    Post subject: Reply with quote
stockcar wrote:
(4x sets RACE front...1x rear) - OILY -PAID
PostPosted: Tue Jun 12, 2012 11:22 am    Post subject: Reply with quote
Quote:
How many questions
Questions were for Stockcar .
But , I know the race config is 2 lines m/cyl to calipers, but radial m/cyl connection is under m/cyl and not on the end so generally has the opposite bend on the end and as the ends are swaged on these, you can't exactly loosen and rotate the end.
PostPosted: Tue Jun 12, 2012 11:26 am    Post subject: Reply with quote
true,... but sb6 doesn't have radials Wink
I used adaptors when I fitted radials,so that I could utilise the original lines Wink
PostPosted: Tue Jun 12, 2012 11:36 am    Post subject: Reply with quote
Neither does a DB4 or a Vdue, but if I am replacing the hose's, I might as well put the radial m/cyl's on that I have in the cupboard for them.
PostPosted: Tue Jun 12, 2012 7:34 pm    Post subject: Reply with quote
obviously the "pattern" would be made as a like for like............if you need something "custom" then there could be a few ways to solve most probably with the "buildline" type kit that i can also sort at similiar discounts........
PostPosted: Tue Jun 12, 2012 10:35 pm    Post subject: Reply with quote
I've got a radial master cylinder and standard lines fit ok. The problem will be the extra line under the master with a banjo brake light switch - you might hit the fairing.
There are radial > non-radial adapters
http://www.ebay.co.uk/itm/Universal-Radial-Master-Cylinder-Adapter-Kit-HEL-PERFORMANCE-/330747773752?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d021a8338
PostPosted: Fri Jun 15, 2012 6:52 pm    Post subject: Reply with quote
have placed an initial order with Goodridge for those sorted so far.............can happily sort more if required
hopefully get everything moving later next week
PostPosted: Fri Jun 22, 2012 7:09 pm    Post subject: Reply with quote
OK so Oily will get a LARGE box on Monday by courier and everyone else should have a friendly postman calling soon............. Laughing
Bimsb6
PostPosted: Fri Jun 22, 2012 7:23 pm    Post subject: Reply with quote
Many thanks in advance .
Page 2 of 3
