Duquois
Posted: Wed Jun 13, 2012 1:33 pm Post subject: SB6 - Temperature Gauge |
During a 60 miles ride last night the temperature gauge on my bike didn't rise above the blue part of the dial. It's the third time I've noticed this. It was quite cool last night. Are they all the same? Thanks for any advice. Andrew _________________ SB6, Moto Guzzi Griso 8v, Guzzi 1100 Sport inj |
MARTIN
Posted: Wed Jun 13, 2012 4:02 pm Post subject: |
Possible,but I would still check two things
Ensure temp gauge sensor is conected on pipework above engine
Ensure that there is coolant and it is flowing around system
be carefull,although header tank above headlights may show
full -rubber hose from expansion tank to pipework may be blocked
or restricted _________________ Marty
Posted: Wed Jun 13, 2012 10:21 pm Post subject: Re: SB6 - Temperature Gauge |
Duquois wrote: |
During a 60 miles ride last night the temperature gauge on my bike didn't rise above the blue part of the dial. It's the third time I've noticed this. It was quite cool last night. Are they all the same? Thanks for any advice. Andrew |
They are pretty in-accurate and temperamental things but check out Marty's suggestions and make sure the cooling system is bled of air properly _________________ SB6 mk1 (project mega light, big bore)
Duquois
Posted: Thu Jun 14, 2012 10:55 pm Post subject: |
Thanks for the advice Martin & Oily, I'll check out those points this weekend. Cheers, Andrew _________________ SB6, Moto Guzzi Griso 8v, Guzzi 1100 Sport inj |
Posted: Thu Jun 14, 2012 11:01 pm Post subject: |
Duquois wrote: |
Thanks for the advice Martin & Oily, I'll check out those points this weekend. Cheers, Andrew |
Don't forget the bleed screw on the metal pipe that runs over the engine and also houses the temp sender _________________ SB6 mk1 (project mega light, big bore)
