Posted: Mon Aug 20, 2012 7:14 pm Post subject: |
OK so that'll be why F1 cars have drain pipes fitted NOT..................
there is a physical limit on the size of the pipe to enable power to be made on a 4stroke, have done some testing with a turbo motor before and lost 30bhp at peak and around 50fl/lbs on a 400bhp engine by substituting the "relatively" restrictive back box with a straight trho pipe the customer had had made and insisted he wanted fitting (it also moved the spool point up the rev range by approx 1500rpm!!) |
Posted: Mon Aug 20, 2012 10:17 pm Post subject: |
Yeh but did it sound better |
Posted: Tue Aug 21, 2012 8:28 am Post subject: |
it sounded "awesome", was measured at around 115db at IDLE.............
just drove absolutley shoite........... |
Posted: Tue Aug 21, 2012 8:56 am Post subject: |
stockcar wrote: |
For my understanding, some English terms are somewhat difficult for me
What do you mean with "spool point" _________________ vince
Posted: Tue Aug 21, 2012 10:40 am Post subject: |
it was on a turbo engine, so the "spool" point is the RPM it starts to make boost (spool up) |
Posted: Tue Aug 21, 2012 11:02 am Post subject: |
And to be fair..........
a huge TURBO engine and a relatively small, underpowered ( ) NA engine have totally different characteristics and require totally different exhaust science
.....but they both need to be LOUD _________________ SB6 mk1 (project mega light, big bore)
mainstone41
Posted: Tue Aug 21, 2012 2:04 pm Post subject: |
Loud is goooood! |
husson73
Posted: Tue Aug 21, 2012 2:21 pm Post subject: |
mainstone41 wrote: |
Loud is goooood! |
and save lifes |
Posted: Tue Aug 21, 2012 4:59 pm Post subject: |
oily wrote: |
.....but they both need to be LOUD |
BUT both need back pressure............ |
CBar
Posted: Fri Aug 24, 2012 11:11 am Post subject: |
My silencers were highly restrictive. This is the 1st thing the exhaust hit.
Then it goes through 3 stages.
Exiting through this.
I was after a some noise, but not LOUD LOUD. I wanted to keep my mid-range for the street. I bought some 1.5" baffles, cut them lengthwise, and tapered them down to match the stock exits. I'm very happy with the results.
Here's a piece of the baffle I used.
mainstone41
Posted: Sat Aug 25, 2012 10:44 am Post subject: |
Interesting to see whats in there, cheers for pics! |
