Vagabond
Posted: Fri Aug 24, 2012 10:52 am Post subject: |
Thanks. I will PM him. |
Posted: Fri Aug 24, 2012 12:34 pm Post subject: |
often on clip-ons there is a "loactor" bolt........
have you tried removing the underneath bolt totally to see if it has a 2nd position?? |
waggy
Posted: Fri Aug 24, 2012 8:16 pm Post subject: |
sorry cant check bars for you as am in austria, but will have a good look next week when i return. Its roasting hot out here, lovely jubbly.  |
Vagabond
Posted: Sat Aug 25, 2012 4:16 am Post subject: |
Thank you waggy. It is beaut weather here in Sydney also. Tesi 3D is an awesome bike to ride but the clip on position is designed more for track than fun rides to the country.
I will try a few more adjustments if I get the time. |
waggy
Posted: Sat Aug 25, 2012 8:58 am Post subject: |
yup they are such a lightweight and well balanced bike, and l just love the braking. The bars are more set for track, but suits me fine as have a knackered arm and straighter bars hurt more, dont let the speedo drop below 80 and its well comfy.  |
waggy
Posted: Thu Aug 30, 2012 5:07 pm Post subject: |
Back from hols, and have had a look at bar setup, your bolt B holds a alloy block to top yoke and your bolt A holds the handlebar assy to the alloy block. loosening either bolt should allow adjustment, however even after removing both bolts everything is still extremely tight (both bolts are loctited) After a long struggle I managed to remove the bar and you can see the end fitting that goes into the alloy block that is attached to the top yoke is tapered. I haven't removed the alloy block that is attached to top yolk as I suspect that that too is tapered and its held fast to all my attempts to shift it so far.
I suspect yours are just as tight all thanks to the tapering design.
Posted: Thu Aug 30, 2012 6:40 pm Post subject: |
Thats actually quite a sensible design, with the tapered end so the bolt pulls it tight, but can still change its postion with a bit of effort, cool
A worthy Addition to the Forum Waggy, be sure to stick around  |
Vagabond
Posted: Fri Aug 31, 2012 7:56 am Post subject: |
"After a long struggle I managed to remove the bar...."
Thanks waggy;
I think this is where I went wrong, I was too afraid to use firm force! |
Vagabond
Posted: Thu Sep 06, 2012 1:28 am Post subject: |
The wing mirrors on the Tesi 3D are next to useless. I am 5' 10", 78 kg and I can't see past my shoulders. Is there a mod to make the mirrors useful for day to day rides?
Thanks. |
waggy
Posted: Thu Sep 06, 2012 5:52 pm Post subject: |
well l am 5'6 and cant see out of my mirrors either, they are more a fashion statement than functional items. Can't think of anything that could replace them, maybe a bar end mirror perhaps. |
daotoys1
Posted: Wed Dec 19, 2012 5:43 pm Post subject: |
Good day,
The small aluminum piece that the clip on bar fits into has a tapered friction fit to the piece that mounts to the steering yoke.
If you loosen the bolt A, and then tap the bolt head lightly it should "break" the friction fit and allow adjustment of the clip on. Only loosen the bolt A a little. Just enough to be able to loosen the friction fit. If you loosen the bolt to much where to few threads are making contact you can damage or strip the threads in the piece that you are attempting to loosen.
I hope that I have explained this well enough for you to make sense of my poor communication skills.
Good luck.
Sincerely
DAO
P.S.......I know this because I have put carbon fiber clip ons on my Tesi 3D ........it took me a little while to figure out how BIMOTA had designed these pieces. |
Vagabond
Posted: Fri Feb 22, 2013 12:01 pm Post subject: |
Both small aluminium pieces in mine have cracked!! However they have been replaced under warranty.
daotoys1
Posted: Fri Feb 22, 2013 4:58 pm Post subject: |
Vagabond wrote: |
I would suggest that anyone who has a Tesi should pay attention to this parts. My guess is that these parts cracked by possibly being over torqued.
Its of course also possible that the parts were just not made strong or thick enough, but over tightening the joint would certainly put the pieces under undue stress and add to the possibility of cracking.
Does anyone know if BIMOTA has a torque setting for these pieces???
DAO |
waggy
Posted: Fri Feb 22, 2013 6:26 pm Post subject: |
wow scary looking cracks there vagabond, as DAO suggested might be a case of overtightening, have no idea of torque values, I didn't tighten mine to much, the tapering design would hold fast I reckon, even if the bolt fell out  |
Vagabond
Posted: Sat Feb 23, 2013 2:13 am Post subject: |
DAO, you're right - there's no torque setting for the aluminium pieces unlike say, the rear axle which is rated to 100Nm. I have never seen torque ratings for an Allan screw head on a Bimota.
However, I think the blocks cracked because it was under tightened, i.e. too loose. When you hit a pot hole, or a bump, the force on the handlebars from your upper torso and arms causes the clip on handlebars to slip downwards making the bike unrideable unless you quickly exert an upward force to pull the bars back in position again (or risk losing control). It is this turning moment I think, that caused the blocks to crack.
IMHO I think there's a design flaw there. If there were friction slots on the aluminium piece and the yoke, there wouldn't be this problem. Just my personal thoughts. Also, the entire rear subframe unscrews itself and you have to constantly check the torsion on the screws. |
