SUSPENSION SET UP DB7
Josema
PostPosted: Tue Nov 24, 2009 8:10 pm    Post subject: SUSPENSION SET UP DB7 Reply with quote
HI FROM SPAIN
I HAVE A DB7 IN CARBON
I NEED INFORMATION ABOU SETUP OF THE SUSPENSION
THE BOOK INFORMATION IS NOT CORRECT
THANKS
No creo ande en desiertos muy remotos ni en montañas muy lejanas
PostPosted: Tue Nov 24, 2009 8:28 pm    Post subject: Reply with quote
Sorry, can't help with your question Josema but welcome to the forum Wink
PostPosted: Wed Nov 25, 2009 3:52 pm    Post subject: Reply with quote
Welcome to the site! Best advise is to go to a suspension specialist with the bike ready to ride it and spend a few hours dialing it in with him instead of spending weeks chasing an error in the wrong direction on your own. Anyone's suggestions will only be relevant for them, we all ride differently on the throttle, on the brakes, sitting position, weight, ride position, etc. etc. The only thing to check on your own would be the front and rear sag prior to messing around with damping. The problem with high performance suspension is that the "sweet spot" is much a much narrower band of error and just 1 or 2 clicks either way can make you feel uneasy. Some riders can ride around a problem by not worrying and never adjust anything for road, track, touring however, if like me you sense every twitch and pressure through the bars and feet when your not expecting it then its worth getting expert help. Lack of confidence takes you off the throttle and bikes always handle better under power driving the suspension down keeping your seat a stable platform while the springs do their thing underneath you. Off the throttle the opposite effect causes the springs to push you up and down instead!
So, after all that... dont waste time just bite the bullet and see a man who can!
Josema
PostPosted: Fri Nov 27, 2009 11:04 pm    Post subject: Reply with quote
I SEND A MAIL TO EXTREMETE TECH AND TO MARRZOCCHI
THIS IS OF EXTREME TECH
For street you can try;
Bump Low: 9
Bump High: 6
Rebound Low: 9
Rebound High: 6
For circuit:
Bump Low: 7
Bump High: 5
Rebound Low: 5
Rebound High: 4
Click from all closed.
Regards
Distinti Saluti
Simone Galeazzi
E. ENGINEERING S.R.L.
Strada Pelosa 183
36100 Vicenza
tel. 0039 0444 240785
fax 0039 0444 240798
www.extremetech.it
PostPosted: Sat Nov 28, 2009 10:07 am    Post subject: Reply with quote
Can I ask how much you weigh?
PostPosted: Sat Nov 28, 2009 10:14 am    Post subject: Reply with quote
Also, what does the bike feel like when you ride it? Does it need a special effort to counter steer in? IS there a return pressure thru the bars once you lean into the apex? Does it weave under power out of the corner or into it? I can give you a rough guide of effect and reaction to clicking up or down if you can think about these questions? Very Happy
Josema
PostPosted: Sun Nov 29, 2009 4:44 pm    Post subject: Reply with quote
no tengo ni idea de lo que me preguntas.
yo peso 75 kg.
Estos son los reglajes standard para circuito y para calle.
Si te gustan bien y sino tambien.
Saludos desde España.
PostPosted: Sun Nov 29, 2009 5:13 pm    Post subject: Reply with quote
And here's the babelfish translation Laughing
I do not have nor idea than you ask to me. I weigh 75 kg. These are the settings standard for circuit and street. If you like well and but also. Greetings from Spain.
PostPosted: Sun Nov 29, 2009 6:24 pm    Post subject: Reply with quote
nice one Oily, Laughing At that weight he should be in the ball park I guess. Let us know how ir performed Josema!
Josema
PostPosted: Mon Nov 30, 2009 10:13 pm    Post subject: Reply with quote
IN THE BALL PARK???
sin comentarios
simpatico Wink
PostPosted: Mon Nov 30, 2009 11:16 pm    Post subject: Reply with quote
ÁREA CORRECTA Wink
bimotard
PostPosted: Thu Dec 03, 2009 10:27 am    Post subject: Reply with quote
Josema, como ves, también estoy en todos los sitios.
Josema, you can see that i am in all the bimota´s places.
