YB6 Sprockets Needed
Alchemist
PostPosted: Mon Dec 10, 2012 12:38 am    Post subject: YB6 Sprockets Needed Reply with quote
I've researched this and according to the AFAM website they make front and rear sprocket as well as chain etc to suit the YB8 which is essentially the same as the YB 6. However the brilliant AUSSIE distributor won't order them to arrive earlier than FEBRUARY !!! Bloody hopeless.
Can anyone in Blighty help me out. I'd like a set 43 and 45 tooth rear, and 15 and 17 front, plus a chain. Any contacts to AFAM dealers at your end appreciated.
cheers for Xmas lads
YB6, Gilera Saturno, Guzzi Lemans Mk1, KTM 640 Advenutre, Honda CB900FC
Bimsb6
PostPosted: Mon Dec 10, 2012 8:20 pm    Post subject: Reply with quote
Www.bandcexpress.co.uk
PostPosted: Mon Dec 10, 2012 9:14 pm    Post subject: Reply with quote
Your chain should be fairly easy to sort out - it's written on the links, then all you need to do is count how many you have, white paint (nail varnish) where you want to start and then mark every known amount.
Take the sproket cover off - use a clutch holding tool and breaker bar to take the front sproket off... or use a rattle gun. look for marks on it, if it looks standard then you want a Yamaha FZR600R foxeye or ThunderCat sproket.
Take the rear off (loosen the nuts with the rear wheel on the floor) and scan it - then you can send it to a sprocket supplier who should be able to get one to suit
Bimsb6
PostPosted: Mon Dec 10, 2012 9:36 pm    Post subject: Reply with quote
Or just buy a kit from b and c ?
Alchemist
PostPosted: Mon Dec 10, 2012 11:33 pm    Post subject: Reply with quote
OK, thanks for the replies but I can't see a Biimota sprocket/chain kit on the B and C website. Will try these guys
http://www.biketorqueracing.co.uk/chains-sprockets/afam-aluminium-rear-sprockets?qsf=1&Make=BIMOTA&Make and Model=BIMOTA~1000 YB8 Exup (530 Conv) 95>
PostPosted: Tue Dec 11, 2012 2:21 pm    Post subject: Reply with quote
As they're in the UK and you're in Aus you'll get bum raped on the postage, all for something that can be sourced over there if you use a bit of savvy.
rOLLI
PostPosted: Wed May 15, 2019 9:55 pm    Post subject: Reply with quote
Dear all,
could someone tell me, which DID chain I have to buy for my YB 8 ?
Which bike is compatible, because Bimota is not listet.
AND : Which bracket do I need. Which is compatible with ours
kind regards
Roland
rOLLI
PostPosted: Wed May 15, 2019 10:04 pm    Post subject: Reply with quote
... dict ... NOT bracket, I meant "rear sprocket"
an link on ebay would help
Bimsb6
PostPosted: Sat Jun 08, 2019 2:04 pm    Post subject: Reply with quote
If you can provide a few measurements from an existing sprocket b&c will make one to order , not expensive either i had them make me one for an sb6 years back .
PostPosted: Sat Jun 08, 2019 6:56 pm    Post subject: Reply with quote
Hi rolli....what wheels does your bike have??.....oscom bimota branded??.. 5 hole or 6 sprocket?
