mainstone41
Posted: Wed Jan 30, 2013 7:23 pm Post subject: Ohlins forks |
Hi chaps, any thoughts on which and how to fit a set of ohlins to me bike and what probs there could be? I saw some where someone had done it, looks good to me! |
Posted: Wed Jan 30, 2013 7:25 pm Post subject: |
Daz has a pair on his 6R _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Jan 30, 2013 10:52 pm Post subject: |
Either way you'll need tripple clamps, clip-ons, mudgaurd, and wheel spindle. I'd say have a look at Ducati S bikes and if you can get the type of fork with axial caliper plates then you'll need 40mm spacing. Obviously if you go for radial brakes then you'll need to add a pair of calipers ... so you'll probably be looking at a grand
On a bike worth 4k ? Not that were concerned with that.
Another way would be to consider a different brand ... WP maybe or something "standard" with a cartridge kit
After all that though remember the speedo runs off the front wheel so you'll be looking to change the clocks too. Personally I'm going to stick with the Paoili, they work OK for now. _________________ Don't read everything you believe |
sb6rdaz
Posted: Thu Jan 31, 2013 2:25 pm Post subject: |
If you can do the front end with Ohlins for £1k you're a better man than me!!!!
You will need all of the above, plus have to mess with wheel and disc spacings. If converting the front to Ohlins, go for the radials and use the calipers to match, may as well jump in for the whole works.
Forks will be close to £1k, but over it by the time you have had them serviced and sorted the springing to suit the heavier SB6.
Yokes will cost you £500ish to have made, someone like Dynamic will make one-off parts, but will take time. Clip-ons around £75-100, then the time and cost to make the spindle and all the caliper/disc spacers.
I started with an Aprilia set of forks, then fitted the Ohlins Superbike internals. The yokes were made by Dynamic, and cost me £600 a good while ago but are very trick and as strong as you could hope for.
If you wanna do the swap, and need more info, PM me, but you will need to be 100% sure you want to make the swap before you can justify the spend. On the road they won't offer a massive improvement, but if you track your bike and push hard, then the difference is huge.
Posted: Thu Jan 31, 2013 3:10 pm Post subject: |
Evilchicken0 wrote: |
Personally I'm going to stick with the Paoili, they work OK for now. |
Personally, I'm going to stick with Paioli because i've got 6 pairs and I can't afford Ohlins. I probably wouldn't notice any difference under normal road riding conditions _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Thu Jan 31, 2013 3:14 pm Post subject: |
oily wrote: |
Personally, I'm going to stick with Paioli because i've got 6 pairs and I can't afford Ohlins. I probably wouldn't notice any difference under normal road riding conditions |
Totally agree there, if ridden on the road, a well serviced and cared for set of the Paioli forks will work just as well in 99 times out of 100 scenarios. And probably better than mine due to the internals I have fitted, which are very track focused.
I used mine as a track bike more than the road, so it worked well for me. The stock Ohlins internals may hold some benfit, but whether a small gain is worth such a large investment is down to the owner really I guess.
mainstone41
Posted: Fri Feb 01, 2013 2:34 pm Post subject: |
Food for thought, umm.. costly and a lot of work. Best think on this a little long. Cheers for responses guys. |
Posted: Fri Feb 01, 2013 2:38 pm Post subject: |
mainstone41 wrote: |
...it would be a faction of the cost to have your RSU46's re worked _________________ SB6 mk1 (project mega light, big bore)
