alanv
Posted: Sun May 19, 2013 1:29 pm Post subject: sb6 bolt size |
| hi all, I have frame protectors fixed to the top motor mount ,if I remove these compleat with the long bolts I will need to replace with std size, any idea what size these are ? thanks AL |
Posted: Sun May 19, 2013 6:20 pm Post subject: Re: sb6 bolt size |
| alanv wrote: |
I can not visualize how your frame protectors are mounted.
Therefore, it is my not clear which bolt you mean.
Can you make a picture.
A picture says more then thousand words.  _________________ vince
Posted: Sun May 19, 2013 8:03 pm Post subject: SB6 Bolt Size |
I'm pretty sure they're M10 x 40 fine pitch. _________________ What, Jonny's gone! |
alanv
Posted: Sun May 19, 2013 9:28 pm Post subject: |
| HI vince, photo not possible at the moment, so in less than a thousand words here goes, the bolt size I need is for the cylinder to frame mount hidden behind the black grommet halfway up the frame rail cheers AL HI jonny, thanks for the info I"ll give your bolt size a go, cheers AL |
alanv
Posted: Sun May 19, 2013 11:16 pm Post subject: |
| HI evilchic I'm unable to use the gauge, as the bolts I need have been replaced with overlength bolts which hold the nylon crash protectors in place, I think VINCE is right, a picture may be required . thanks AL |
CBar
Posted: Fri May 24, 2013 11:48 pm Post subject: Re: SB6 Bolt Size |
| Jonny B Bad wrote: |
| I'm pretty sure they're M10 x 40 fine pitch. |
This is it.
[/img] |
Posted: Sat May 25, 2013 10:14 am Post subject: |
Measure the threaded shaft not the bolt head. Although, if you measure the shaft and ad 4 (generally) you'll get the AF or spanner size _________________ Don't read everything you believe |
alanv
Posted: Mon May 27, 2013 4:43 pm Post subject: |
| cheers evilchic. just the job mate. |
alanv
Posted: Mon May 27, 2013 4:50 pm Post subject: |
| thankyou cbar. spot on pictures, cheers AL |
