Posted: Fri Jan 03, 2014 12:58 pm Post subject: whats its name?? |
Hi chaps
I'm looking for some of the rubber ring parts that fit around the fork leg in between the fork top and bottom yokes that cushion the forks against the frame on full lock. Anyone know what their proper name is and where I may be able to get them?? I know they are different sizes depending on fork diameter but first things first
cheers  _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Posted: Fri Jan 03, 2014 5:36 pm Post subject: |
according to the SB6/7 spare parts catalogue is referred to "Bumper"
I have no idea how to get them. But let me know if you do. _________________ vince
Posted: Fri Jan 03, 2014 8:43 pm Post subject: |
Some place like McMaster-Carr might have something that would work. _________________ Spike C.
1965 Triumph T100SC |
Posted: Sat Jan 04, 2014 1:05 am Post subject: |
| I reckon youd be best off finding inch thick rubber sheeting and using hole cutter drill attachments to make outer and cut inner hole sizes...or foam pipe lagging and cable tie them on... |
Posted: Sat Jan 04, 2014 10:37 am Post subject: |
yes seen them on ebay - they look a bit thin as they are for mountain bikes, but will have a look in nearest MBX shop.38mm for the KB1 - the Christmas boredom spanners came out of the drawer and the rest is history -ooops!!  _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Frank.61
Joined: 28 Nov 2013 Posts: 108 Location: Maasmechelen, Belgium
Posted: Sun Jan 05, 2014 10:36 pm Post subject: |
Your better off sourcing some blocks of rubber and having them cut. Its not just getting the internal DOA right its the external which dictates the lock. _________________ Don't read everything you believe |
