Many Bimota parts for sale, most models.
chazawatsit
PostPosted: Mon Feb 17, 2014 10:52 pm    Post subject: Many Bimota parts for sale, most models. Reply with quote
Hey guys,
I have finally sorted through all the Bimota parts which I had left and the following is a list of every part and the price of each.
If you would like anything please send me a message and I will calculate postage and get back to you ASAP. I am willing to post all over the world so just message me if you would like any parts or any more information about anything.
Here is the list of all parts available:
DB2 SR - Electric Wiring Harness Plate x 2 - £5.00 each
Tesi 1D - Handlebar Knuckle - £50.00
DB1 - Shift Linkage Thread Rod - £70.00
YB8 EVO / YB9 / YB11 - RH Footrest Hangar - £50.00
Tesi - Rear Engine Pin x 2 - £25.00 each
YB8 - Engine Stop Plate Right Cylinder Head - £50.00
DB3 Mantra - Left Handlebar - £50.00
YB11 - Rear Subframe - £120.00
SB6R - ITG Race Filter - £60.00
SB6 / SB7 - Castle Stator x 9 - £2.00 each
SB6 / SB7 / SB6R - Front Wheel Spindle Nuts x 4 - £20.00 each
YB9 / YB9 SRI - Upper Chain Guard - £35.00
BB1 / DB3 - Side Stand Switch - £25.00
YB9 / Mantra - Paioli Preload Kit 43mm Forks - £180.00
Pre 1990 model - RH Mirror with Fixings - £25.00
SB6 / SB7 - RH + LH Mirror Arms - £50.00
DB2 - Black RH Mirror Arm - £25.00
YB8 - RH Mirror Arm - £25.00
DB2 - Red LH Mirror Arm - £25.00
BB1 - LH Mirror Arm - £25.00
DB2 - LH + RH Fairing Supports - £40.00
BB1 - Chain Runner - £15.00
YB11 - Rear RH Footrest Hangar - £40.00
SB6 Fuel Tap - £30.00
YB10 - Rear Seat Back Cushion - £10.00
SB6 / SB7 - Shift Linkage Thread Rod - £30.00
SB6 / SB7 - Breather Extensions x 2 - £5.00 each
BB1 - LH Footrest Hangar x 2 - £30.00 each
BB1 - RH Footrest Hangar - £30.00
YB4 - Fuel Hose/Pipe - £30.00
YB8 Evo - Shift Linkage Thread Rod x 3 - £20.00 each
BB1 Supermono - Lock Set - £100.00
DB3 Mantra - Lock Set x 3 - £140.00 each
Mantra - Frame Caps x 2 - £15.00 each
Mantra - Shift Linkage Rod - £20.00
YB10 - LH Front Indicator x 2 - £20.00 each
YB11 - Rear Bottom Fairing Bracket - £10.00
Look forward to hearing from you all
Kind Regards
Charlie
chazawatsit
PostPosted: Mon Feb 17, 2014 10:53 pm    Post subject: Reply with quote
Alternatively you can contact me on charliebhp@aol.com
