Sprag clutch.
Goto page 1, 2, 3  Next
PostPosted: Tue Sep 17, 2013 3:35 pm    Post subject: Sprag clutch. Reply with quote
Thought I would put up a few pictures of what will face you when the sprag bearing plays up.
After the initial fairings off and the clutch cover and pressure plate/clutch plates out , the first obstacle is this, a nice round 60mm diameter nut.
Once a suitable tool can be found , apparently very common in Italy, but not so in the UK .
The front frame mount doubles up as a nice 3rd hand for the clutch basket holding tool.
After a good lever with a long bar and a few shift kicks of frustration of the vdue tyre the nut finally lets go and with renewed enthusiasm its the 15-20 m6 bolts removed to get the engine cover off. A bit of ' operation' with the cover to get it passed the frame etc , and a swift removal of the idler gear , we are there !! (top gear on right).
Whip the sprag housing off , removing the 4 m4 crappy csk bolts and thats it , bearing revealed !!
And only if it was that easy.
851jim
PostPosted: Mon Sep 23, 2013 4:56 pm    Post subject: Reply with quote
Hi Stu
Be aware of air locks when you start up again.
PostPosted: Tue Sep 24, 2013 8:43 pm    Post subject: Reply with quote
Air locks in oil or water ?
PostPosted: Tue Sep 24, 2013 11:18 pm    Post subject: Reply with quote
Air in the tires Confused
Trev
851jim
PostPosted: Wed Sep 25, 2013 4:28 am    Post subject: Reply with quote
Bleed the oil is easy.
Getting rid of cooling air lock if you get one is difficult.
The water temp might not show as high but the header tank gets a bit steamy.
PostPosted: Wed Sep 25, 2013 7:19 am    Post subject: Reply with quote
not an issue with my vdue....temp gauge stuck on first led 40 degrees and never shows anything else... Sad
mm500
PostPosted: Wed Feb 19, 2014 10:51 pm    Post subject: Reply with quote
great write up Smile
mm500
PostPosted: Wed Mar 19, 2014 8:57 pm    Post subject: Reply with quote
will a ducati clutch tool fitt?
PostPosted: Wed Mar 19, 2014 9:07 pm    Post subject: Reply with quote
Vorts a mate of mine...and I picked up the clutch tool for him.......its a standard Ducati clutch tool and fits.....yup
mm500
PostPosted: Wed Mar 19, 2014 9:11 pm    Post subject: Reply with quote
thanks for the fast reply Very Happy
PostPosted: Wed Mar 19, 2014 10:01 pm    Post subject: Reply with quote
hub holding tool from witch model Ducati ?
Might get new one , love new tools
Trev
mm500
PostPosted: Wed Mar 19, 2014 10:18 pm    Post subject: Reply with quote
I think all the ducati dry clutches are the same
748, 749, 999, 1098, 1198 etc
PostPosted: Wed Mar 19, 2014 10:19 pm    Post subject: Reply with quote
Any of them from a 1990 900ss right up to Ducati 1098....all same clutches, baskets, hubs etc..........Cost around 25 GBP new...but they;re that ruddy heavy the postage could cost the same if ebaying one......
PostPosted: Thu Mar 20, 2014 8:36 am    Post subject: Reply with quote
I did buy one of those little one's that attach to the clutch cover fixing bolts, but guess what ???? Bimota decide not only to use a different bolt arrangement for the clutch basket but also use a different bolt pattern to Ducati for clutch cover so it does not fit. !!!!!!
I'm with 2bim's, the spanner type tool must weigh about 6-8kg.
PostPosted: Tue Jul 01, 2014 9:55 pm    Post subject: Reply with quote
Just found out (thank god!) that the clutch holding tool is common to Benelli Tornado as well......
Page 1 of 3
