chazawatsit
Posted: Sat Jun 14, 2014 4:24 pm Post subject: Bimota Parts for Sale |
Hi there,
We have the following parts for sale:
DB2 SR - Electric Wiring Harness Plate x 2 - £5.00 each
Tesi 1D - Handlebar Knuckle - £50.00
DB1 - Shift Linkage Thread Rod - £70.00
YB8 EVO / YB9 / YB11 - RH Footrest Hangar - £50.00
Tesi - Rear Engine Pin x 2 - £25.00 each
YB8 - Engine Stop Plate Right Cylinder Head - £50.00
DB3 Mantra - Left Handlebar - £50.00
YB11 - Rear Subframe - £120.00
SB6R - ITG Race Filter - £60.00
SB6 / SB7 - Castle Stator x 9 - £2.00 each
SB6 / SB7 / SB6R - Front Wheel Spindle Nuts x 4 - £20.00 each
YB9 / YB9 SRI - Upper Chain Guard - £35.00
BB1 / DB3 - Side Stand Switch - £25.00
YB9 / Mantra - Paioli Preload Kit 43mm Forks - £180.00
Pre 1990 model - RH Mirror with Fixings - £25.00
SB6 / SB7 - RH + LH Mirror Arms - £50.00
DB2 - Black RH Mirror Arm - £25.00
YB8 - RH Mirror Arm - £25.00
DB2 - Red LH Mirror Arm - £25.00
BB1 - LH Mirror Arm - £25.00
DB2 - LH + RH Fairing Supports - £40.00
BB1 - Chain Runner - £15.00
YB11 - Rear RH Footrest Hangar - £40.00
SB6 Fuel Tap - £30.00
YB10 - Rear Seat Back Cushion - £10.00
SB6 / SB7 - Shift Linkage Thread Rod - £30.00
SB6 / SB7 - Breather Extensions x 2 - £5.00 each
BB1 - LH Footrest Hangar x 2 - £30.00 each
BB1 - RH Footrest Hangar - £30.00
YB4 - Fuel Hose/Pipe - £30.00
YB8 Evo - Shift Linkage Thread Rod x 3 - £20.00 each
BB1 Supermono - Lock Set - £100.00
DB3 Mantra - Lock Set x 3 - £140.00 each
Mantra - Frame Caps x 2 - £15.00 each
Mantra - Shift Linkage Rod - £20.00
YB10 - LH Front Indicator x 2 - £20.00 each
YB11 - Rear Bottom Fairing Bracket - £10.00
PM me if you are interested
Regards
Simon Watson
Race Engineering |
