hnracing
Joined: 15 Apr 2012 Posts: 43 Location: Gothenburg Sweden
Posted: Sun Nov 30, 2014 10:30 pm Post subject: |
DB4 swing vs 1000SS swing vs 900SSie swing
_________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project |
hnracing
Posted: Sun Nov 30, 2014 10:32 pm Post subject: |
SSie steering pin shortended 30mm
hnracing
Posted: Sun Nov 30, 2014 10:42 pm Post subject: |
Some weight and dimension values
My weight 76,5 kg
1100SS trackbike without fuel 157 kg
Frame 1000SS 12,3 kg
Frame 1000SS with rear cut directly behind the exhaust bracket 10,3 kg
Frame DB4 5,3 kg
Swing 1000SS 4,1 kg
Swing 900SSie 3,6 kg
Swing DB4 3,6 kg
Alu tank with cap no pump no filter 2,5 kg
Tank dummy 1,8 kg
Rear damper Öhlins 1000SS 3,4 kg
Rear damper Nitron 2,9 kg
Rear damper Öhlins 1000SS lenght 340mm with 7mm thread visible
Rear damper Nitron lenght 330 with 5mm thread visible
Swing 1000SS distance swingaxel - rearaxel 474 - 488 - 501 mm min middle max
Swing 900SSie distance swingaxel - rearaxel 469 - 488 - 506 mm min middle max
Swing DB4 distance swingaxel - rearaxel 445 - 460 - 475 mm min middle max _________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project |
deebee4
Posted: Sun Nov 30, 2014 11:20 pm Post subject: |
Cool pictures and nice data for comparisment.
db4 frame really is light. And shorter with more steep steering head angle.
I think you will love the snappy handling compared to the Ducati frames.
Only difference might be offset value of the Ducati forks compared to the Bimota forks. If you want values I would have to measure them up. _________________ Track riding on a Bimota: FUN! |
Posted: Mon Dec 01, 2014 12:26 am Post subject: |
I am really looking frward to this build! Nice pics comparing the frames and swingers. I'm suprized how much lighter the db4 frame is. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
polyesterpig
Posted: Mon Dec 01, 2014 7:02 pm Post subject: |
Bimota welds are so pretty! _________________ Spike C.
1965 Triumph T100SC |
hnracing
Posted: Tue Dec 02, 2014 3:20 pm Post subject: |
deebee4 wrote: |
Only difference might be offset value of the Ducati forks compared to the Bimota forks. If you want values I would have to measure them up. |
Yes I really hope that the short wheelbase, more steep steering head angle and less weight will give a really snappy handling of the bike.
The offset is 30mm for the SSie triples / yokes.
Please measure yours
/Henrik _________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project
hnracing
polyesterpig
Posted: Tue Dec 02, 2014 6:43 pm Post subject: |
The stock DB4 yoke offset is 35mm. I am thinking of putting on 30mm offset triples too because I want to put on more modern UPSD forks. I was told there might be an issue of the front tire contacting the engine upon hard braking? I have an extra custom made billet 35mm offset top clamp with an alloy stem that fits the Ducati ohlins forks and lower yoke for the DB4. I bought it from Moto Corse Performance in Florida a couple years ago. I never installed it. If I can find the time to post a picture, I will. _________________ 2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto |
hnracing
Posted: Tue Dec 02, 2014 9:23 pm Post subject: |
Interesting!
Share a photo of it. _________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project |
hnracing
Posted: Tue Dec 02, 2014 9:26 pm Post subject: |
Found some useful parts at Yahoo in Japan.
Package sent 25 November, arrived in Sweden 1 December !
Frame plugs.
Should there be a O-ring around them ?
Or just the locking screw in the frame?
[/list] _________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project |
hnracing
Posted: Tue Dec 02, 2014 9:29 pm Post subject: |
Rear brake setup
Have anyone tried to mount the rearbrake mastercylinder to the engine like Ducati do?
Will the distance from the pedal to the rearseat be ok?
polyesterpig
Posted: Tue Dec 02, 2014 9:41 pm Post subject: |
[quote="hnracing"]Found some useful parts at Yahoo in Japan.
Frame plugs.
quote]
No o-rings on the plugs, just the screw. _________________ 2002 Cannondale E440
hnracing
Posted: Tue Dec 02, 2014 9:42 pm Post subject: |
Thanks! _________________ Monster 1100 -96 for the road / 1100SS for the track / DB4 new track project |
