Swingarm
PostPosted: Fri Feb 20, 2015 2:58 pm    Post subject: Swingarm Reply with quote
Is the Vdue Swingarm different to the SB6R ?
This is a just wondering thing
PostPosted: Fri Feb 20, 2015 5:02 pm    Post subject: V-due swingarm Reply with quote
Hello Chuckie
Can't be sure, but they do look frighteningly similar.
PostPosted: Fri Feb 20, 2015 8:19 pm    Post subject: Reply with quote
Vorts VDue has an SB8k swinger on it, identical except it has stand bobbins on it (Vdues are welded up)
PostPosted: Fri Feb 20, 2015 9:49 pm    Post subject: Reply with quote
SB8R swing arm is the same BUT
The early VDUE had a smaller axle
The SB8R swing arm has a bigger axle
The SB8R swing arm was used in the VDUE race bikes
and almost every carby model VDUE
You can not just change bearings it is a different wheel needed
if you go to the SB8R swing arm but there are more wheel
choices in the SB8R axle size set up anyway
Trev
PostPosted: Fri Feb 20, 2015 9:50 pm    Post subject: Reply with quote
The SB8R front wheel is the same as the VDUE front wheel
Trev
PostPosted: Fri Feb 20, 2015 10:16 pm    Post subject: Re: V-due swingarm Reply with quote
Jonny B Bad wrote:
Hello Chuckie
Don't they just.
The SB6 arm doesn't have the same bracing on the shock mount. The 6R has that, but maybe the SB8R is an alternative
PostPosted: Mon Mar 02, 2015 8:16 pm    Post subject: Reply with quote
Trev
Well I have seen a fair few carb jolly moto vdues and 3 trofeo vdues and out of these 8 or so vdues only 2 have got the SB8R/K swing arm.
My vdue was the first I had seen and I did not realise at the time it had a different swing arm. It was only when I ordered a set of Dymag wheels I discovered the difference. It was not in the bearing or spindle size that was different, but the swing arm width.
However I can confirm my SB8K does have a larger spindle size.
SethG
PostPosted: Tue Mar 03, 2015 1:34 am    Post subject: Reply with quote
So puzzling, I wonder what the benefit was of that swingarm?
PostPosted: Tue Mar 03, 2015 6:14 am    Post subject: Reply with quote
Bigger axle is better
Trev
Matty82
PostPosted: Tue Mar 03, 2015 12:44 pm    Post subject: Reply with quote
Hi, does anyone have the width of the larger spindle an the wider swing arm
2SMOKE
PostPosted: Tue Mar 03, 2015 1:57 pm    Post subject: Reply with quote
When I went to visit Piero and asked about vdue differences and model variants his answer was quite simple .
Depends what was available at the time.
On the SB8K swing arm, from memory it is 5,5-6mm wider at the spindle , spindle size of the 8K I dont know off hand but guess a good 5-8mm on diameter and hollow , for greater stiffness and less weight.
However the vdues I have seen with the SB8k swinger do not have the SB8K diameter spindle. It is the standard vdue diameter spindle , circa 22-25mm ish.
