Posted: Wed Mar 04, 2015 3:33 pm Post subject: |
will do Trev _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Wed Mar 04, 2015 3:35 pm Post subject: |
today I chopped some more redundant wiring out of the Tesi's loom - who needs a fuse box on a race bike?
and sorted the wiring runs - the CPU / relays / air pressure and temp sensors awaiting their "custom" mounting plate up front......
right-side, having removed the front of the battery carrier to allow easier access and discovered just where the 2 coils locate.........
not so much wiring to tape up now.....
Posted: Wed Mar 04, 2015 11:36 pm Post subject: |
DOH
Trev |
Posted: Fri Mar 06, 2015 7:34 pm Post subject: |
the coils have 4 mounting points each. On the Tesi, the front coil only uses 1 mounting and the rear coil 2. I was looking for 4 for each coil.......................doh _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Fri Mar 06, 2015 11:30 pm Post subject: |
Well it will be running by the end of the day then
Trev |
Posted: Tue Mar 10, 2015 3:34 am Post subject: |
the 2 engine management relays (underneath) and the air pressure sensor (on top) on their mounting plate located on the front fairing stay........
with the air temp sensor ( the little red bulb in front of the relays) at the front of the plate
need to fabricate a mounting for the CPU now...... _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Mon Mar 16, 2015 2:11 am Post subject: |
the front swing-arm pins arrived from Bimota Classic parts - thanks Paolo
now I have to strip the bike again to fit them and the new bearings...... _________________ Bimota SB6 and Benelli TNT 899S road bikes.
also the Ducati 996 starter solenoid arrived - that completes the electrical componentry required to get this project running.
so - its off with one of the Omega plates, remove the temporary aluminium bush, fit a new bearing and the pivot pin then repeat for the other plate.
Easier said than done.................... _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Tesikwak
Joined: 05 Sep 2013 Posts: 62 Location: Adelaide, Australia
Posted: Mon Mar 16, 2015 8:57 am Post subject: |
GeeKay wrote: |
now I have to strip the bike again to fit them and the new bearings...... |
Are they easy to get bearings or specials? If easy, what are the part numbers? Yes I know, I'm picking your brains again. and were the pins expensive from Paolo? I will more than likely order a pair from him. _________________ If I don't force my opinion onto others; I expect the same from them! |
Posted: Mon Mar 16, 2015 12:52 pm Post subject: |
Hi Vince
pins were 79 Euros for 2 sets + shipping.
spent all morning trying to find replacement bearings - have secured a pair close by.
they are 24mm o/d x 12mm i/d x 13mm wide with a lube groove in the outer shell. The 12mm i/d is achieved by them having a hardened steel liner fitted (16mm o/d x 12mm i/d) otherwise the bearings alone are 24mm o/d x 16mm i/d.
If that makes any sense at all to an engineer
I will give you the bearing code when I have collected them. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Mon Mar 16, 2015 11:28 pm Post subject: |
so - off with the right-hand plate..........
then time to employ some very basic engineering - large socket in vice.......
carefully support the frame plate ............
this is the offending bush that needs removing........
tools of the trade...........
and it's out...........
the bolt, nut and bush that I've used on both sides of the frame to enable the bike to stay mobile - now to be replaced with the correct pins and bearings
Tesikwak
Posted: Tue Mar 17, 2015 9:20 am Post subject: |
Could be these ones:- NA4901 UU Needle roller bearing 12 x 24 x 14 mm Metric. _________________ If I don't force my opinion onto others; I expect the same from them! |
Posted: Mon Mar 23, 2015 4:11 pm Post subject: |
Hi Vince
bearing code is :- NA4901 R.
note - they do not come with the "o" rings that seal between the outer bearing race and the spacer.
Posted: Wed Mar 25, 2015 11:43 pm Post subject: |
drilling the new oil cooler for the cylinder heads cams feed pipe.......
tapped to take the banjo bolt................
and fitted..............
the front swing-arm, mounted on it's newly acquired pivot pins and new bearings........
then I made a mounting plate out of polyprop sheet for the ECU, fitted the rubber mounts, tie-wrapped the plate to the front fairing bracket and mounted the ECU.
Few bits left to do, then its ready for displaying at the Manchester Bike Show on Friday _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Thu Mar 26, 2015 12:13 am Post subject: |
Nice to see the progress Geekay.........will she be coming to the show with clothes on....or naked????.....
Been digging out a few bits and pieces for you...so will be interesting to see whether you still need them or not......nice to see 2 clip-ons also......that fooled a few people at the show 2 years ago when there was only one.......... |
