steff_dk
Posted: Sat Sep 19, 2015 5:28 pm Post subject: Crankcase seals ... anyone? |
So I found myself reading this article again, and found mention of crankcase issues added to it in 2013:
odd-bike.com wrote: |
Ed. Note December 2013 - Since writing this piece in 2012 I've learned that the main problem with the V-Due is improper crankcase sealing due to flaws in the crankcase castings, not simply a wonky fuel injection setup. You can fix a V-Due! Bob Steinbugler at Bimota Spirit offers newly manufactured crankcases that fix this issue and allow you to rebuild the V-Due into the screaming sport weapon it was meant to be. If only Bimota had known...
Has anyone experienced these issues with their bike? |
EYREY1
Posted: Mon Sep 21, 2015 12:27 am Post subject: |
i will be pressure testing mine before fitting it back in the bike
just to make sure , last person to build my engine did use a lot of red hematite on the crank case halfs |
Posted: Mon Sep 21, 2015 1:02 pm Post subject: Re: Crankcase seals ... anyone? |
steff_dk wrote: |
I suppose that all depends what age the injection bike he had ?
The later bikes and reworked bikes have different crank case's anyway , so is it the early bikes that had the issue only ?
If you go to see Piero he has creates of NOS casings that he says are scrap. |
steff_dk
Posted: Mon Sep 21, 2015 8:41 pm Post subject: Re: Crankcase seals ... anyone? |
vort28 wrote: |
Okay - didn't know the crankcases changed on the later bikes - cheers Stu |
