WHICH FIAT ECU SUITS A 1999 SB8RS
roughrider
PostPosted: Tue Sep 22, 2015 5:25 pm    Post subject: WHICH FIAT ECU SUITS A 1999 SB8RS Reply with quote
Please can somebody categorically state which of the following Magneti Marelli ECU's will work on a 1999 SB8RS, and is it simply a case of swapping the EPROM? My ECU has Microtec written on it, and is identical in appearance to IAW 6F SB off a Punto.
Cincequento IAW 16F ER
Cincequento IAW 16F EO
Or please supply the correct code. The bike will not run, there is no spark or injector signal. All engine sensors are working, and the ECU has been tested on a very helpful individuals bike.
Any help much appreciated
