Choke cable SB6
PostPosted: Fri Aug 13, 2010 9:56 am    Post subject: Choke cable SB6 Reply with quote
I think the choke cable on my 6 might be sticking. The bike sometimes wants to tick over at 3k, I blip the throttle and still does it then move the choke lever a bit mor "on" and it ticks over more normally.
I haven't got in there to have a look about yet, it could be the return spring on the carbs, but if it is the cable ....
Where can get a standard replacement ??? (other than Venhill)
husson73
PostPosted: Fri Aug 13, 2010 10:10 am    Post subject: Reply with quote
Got the double throttle cable for my six from french bimota which hasn't it in stock and got it from factory in on week, so try Bimota uk.
PostPosted: Fri Aug 13, 2010 10:46 am    Post subject: Reply with quote
If I recall rightly rpo83 was looking into a choke cable for his.
Give him a PM and see if he solved the problem.
We decided the switchgear was CBR so you might end up making one Wink
PostPosted: Fri Aug 13, 2010 5:36 pm    Post subject: Reply with quote
I'll drop him a PM
