jirka-st2
Joined: 15 Aug 2010 Posts: 5 Location: Czech Republic
Posted: Sun Aug 15, 2010 4:24 pm Post subject: DB6R Delirio circumference setting |
Hello everybody,
I am new owner od DB6R Delirio and only one problem I see. The speedometer shows speed, which is in km/h higher aprox. for 20%. Is it possible to adjust somehow the speedometer - egg. circumference setting? I´ve looked at Koso rx2 manual, which is the same type of speedometer, but these functions, how to open service screen are inactive. Thank you in advance for help.
Jiri |
Posted: Sun Aug 15, 2010 9:48 pm Post subject: |
I'd replace the clock with a Koso aftermarket unit until Bimota sort them out it should be a striaht for plug in _________________ Don't read everything you believe |
waldorf
Posted: Fri Oct 01, 2010 1:38 pm Post subject: |
The Marelli ECU should have a 10% offset in the peed reading when stock.
That setting can be changed with the Tuneboy software but I highly recommend changing the ECU to a Microtec or Nemesis _________________ Olivier |
