PaulDB2
Posted: Wed Mar 08, 2017 1:38 pm Post subject: Battery for DB1 - Orientation? |
Hoping some kind soul can help out here. Just about to order a battery for my DB1 and realised I am not sure which way round the battery terminals need to be. (The DB1 did not have a battery when I imported it - transit rules).
The battery type I believe is a YB14L, but is it an A2 or a B2?
Do the terminals on the battery sit towards the front of the bike or towards the rear when mounted in it's frame?
The positive terminals in my wiring harness seem to indicate the positive terminal on the battery should be on the left side (as sat on the bike). _________________ Bimota DB1, Bimota YB5, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, Moto Guzzi 750 S3, Honda CR750 race replica, Seeley-Suzuki TR500 |
Quadrasuarass
Posted: Wed Mar 08, 2017 8:48 pm Post subject: |
Will have a look for pics this evening from my resto project. Meanwhile heave you considered a Lithium Ion Battery. I have been recommended Motobat by a knowledgeable electrical engineer who is fully conversant with the foibles of Ducatis and there brethren. 1/2 the size and 1/3 the weight with a higher cold cranking capacity. I've also moded the battery box to suit this which opens up space under it to let more air in over the back cylinder head. |
Quadrasuarass
PaulDB2
Posted: Wed Mar 08, 2017 9:24 pm Post subject: |
Thanks Quadrasuarass, thanks for looking. Not really considered lithium ion battery, but I will look at them also, not as expensive as I thought previously. Don't really want to start hacking the battery box about, but getting more air around the motor is a plus. _________________ Bimota DB1, Bimota YB5, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, Moto Guzzi 750 S3, Honda CR750 race replica, Seeley-Suzuki TR500 |
Quadrasuarass
Posted: Thu Mar 09, 2017 6:23 am Post subject: |
First shot is original battery, positive terminals to the front, positive on the left when sitting on the bike as you noted.
Second shot is comparison with Ultrabat - 3 module (not Motobat as previously mentioned)
3rd Shot is normal Ultrabat Install
4th and 5th shots are my mock up of ultrabat install from the side and front. You can see the extra opening available below the battery to let air over the rear cylinder head
Battery box was lightly modified with a hole saw to get air over the LiPo battery and tin snips/vicegrips to create a landing for the smaller battery to sit on, then all off to the powder coater for a fresh coat of paint.
Nigel |
Posted: Thu Mar 09, 2017 9:39 am Post subject: |
Lovely work....But just what are those valve covers made of???? They look like 1950's Bakerlite like my Grandads Old Roberts Radio??? |
PaulDB2
Posted: Thu Mar 09, 2017 11:18 am Post subject: |
Thanks Quadrasuarass, that helps a great deal.
Is that steering damper original, mine is circular in section?
Are the valve covers magnesium? _________________ Bimota DB1, Bimota YB5, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, Moto Guzzi 750 S3, Honda CR750 race replica, Seeley-Suzuki TR500 |
Quadrasuarass
Posted: Thu Mar 09, 2017 9:41 pm Post subject: |
Valve covers are standard that have been pimped up a bit with some flash powder coating. I believe that the steering damper is standard.
Bike was really tatty when I got it; project name is DBling1 which gives you an idea of where this is heading.
Nigel |
Posted: Fri Mar 10, 2017 1:21 am Post subject: |
Quadrasuarass wrote: |
Nigel |
Different damper body and clamp from that on my DB1....but heck...twud be whatever they could get hold of I imagine...as per the norm... |
Quadrasuarass
Posted: Fri Mar 10, 2017 3:44 am Post subject: |
Having said it was on the bike when I got it the damper also has a non standard bracket to hold it away from the frame and let it work properly so maybe mine is not original. No markings on it to say what it is but it works fine |
Posted: Fri Mar 10, 2017 6:54 am Post subject: |
None of the early db series. 1, 2 or 4 have markings on the dampers to say who made them...so maybe... |
