Posted: Fri Mar 24, 2017 1:08 am Post subject: DB5R Brembo clutch master gone south? |
Has this happened to anyone? My bike has axial gold remote res brembos and the fluid went down to the point that the clutch was mostly inoperable. I topped it up, which usaually fixes these things, but not this time I bled the crap out of the slave, (an EVR) and no joy, I added a bleeder to a he master and beld the shit it of that, and still, if I pull the lever slowly there is no resistance, if I pull it rapidly here is. Holding the lever in then goes soft after a bit. _________________ Spike C.
1965 Triumph T100SC |
Weed
Posted: Fri Mar 24, 2017 4:12 am Post subject: |
Looks like you need to buy a seal kit for it |
Posted: Fri Mar 24, 2017 9:42 am Post subject: |
Are you sure its the master and not the slave???????? The slaves are Ducati items and notoriously prone to failing on the seal...thus pump away all you like...all the fluid will end up in your front sprocket casing...and then run down your engine and strip your paint...unless of course you can see it leaking on the master...the brembo stuff rarely goes wrong...ducati stuff...well...so much so that Ducati have discontinued it as a spare....so do yourself a favour and buy an Oberon clutch slave...available in many anodised finishes....or black...or bare silver....cheaper than what was the duc unit...hence Ducati stop selling them...and...its guaranteed for life...AND....the ratios are better for an easier clutch pull...also check clutch lines aren't leaking at the banjos etc etc |
Posted: Fri Mar 24, 2017 6:45 pm Post subject: |
Thanks 32bims, I have an EVR slave that is not leaking. _________________ Spike C.
Posted: Sat Mar 25, 2017 1:00 am Post subject: |
OK...and then if all olive joints are tight and no signs of leaking...its defo your brembo gold series master piston seal that's gone....not leaking, cos its airtight...and fluid isn't being pumped.....KTM do seal replacement kits for Brembo.....maybe Ducati....but brembo no....theywont take the liability of selling them...if its not a radial brembo master...then upgrade to one....better ratios and feel...lighter pull...uses same res pot and mounting is all you would need to check...and the all important little clutch switch that needs to operate or bike wont start |
yb11reno
Joined: 14 Feb 2015 Posts: 111 Location: Reno, NV USA
Posted: Sat Mar 25, 2017 6:51 pm Post subject: |
Is the fluid continuing to leak out someplace? Or is the fluid level staying up with the issue being a low resistance pull on the clutch lever? You haven't by chance had the clutch plates out recently have you? _________________ Jack
Reno, NV |
Posted: Mon Apr 03, 2017 3:47 am Post subject: |
OK, I resolved the issue. It turns out that bleeding the clutch circuit on these Ducati motors can be somewhat problematical. I went through about 10 ounces of fluid before I finally got the thing to work.
I had to push the slave cylinder piston all of the way in, then begin again. That seemed to move the air bubble into a position where it could be evacuated. _________________ Spike C.
