runesika
Posted: Tue May 30, 2017 9:09 pm Post subject: Clutch problems. My fault but I'm blaming the dog ! |
With the combination of incompetence on my part and a large clumsy Deerhound I've managed to mix up my clutch plate order with my spare clutch .
Does anyone know the correct order or stack height for the VDue ? The manual I have downloaded says six friction and six steels but I have some convex ones and thick and thin steels
I'm sure I'll get to the bottom of it but if anyone knows please help ! |
runesika
Posted: Sun Jun 04, 2017 9:39 am Post subject: |
All sorted but only after three attempts .
I used a Ducati 996 friction plate only set from eBay , you get seven plates but only six used in the V DUE .
Started with a steel , then a convex side facing out then friction , steel , etc .
I had some thick and thinner steel plates so brought the stack pretty much flush to the clutch centre , line up the arrow on the pressure plate with the dot and now road tested .
Reading the Ducati forums it really doesn't seem to matter too much what you do ! Some have one convex facing out and finish with one facing in , others only have one . |
Posted: Fri Jun 09, 2017 11:36 pm Post subject: |
Glad you got it sorted. How does the new clutch feel? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
runesika
Posted: Sat Jun 10, 2017 12:03 pm Post subject: |
Hi , thanks .
It feels as good as a dry crotch sorry "clutch " can , but I'm really not a fan of them .
Feels a little heavy as the springs are preloaded with two washers each ( I don't know if they are like that standard ? ) but otherwise fine and holding full torque top gear runs without slipping .
Only using non sintered 996 plates so I'll see how it lasts . |
