Post a picture of your Bimota
Goto page Previous  1, 2, 3 ... 31, 32, 33 ... 35, 36, 37  Next
PostPosted: Thu May 04, 2017 3:12 pm    Post subject: SB6R Reply with quote
You've got me started now and I may struggle to shut up until everybody's fallen asleep! This bike was designed to benefit from a ram-air effect. However, whilst all of the 6Rs I've come across seem to connect the float bowl breather to the air box lid, via a filter (see below), not all seem to plug the under-slide breathers into the air box lid, as they should be. Something else to check.
And another thing, the filter on the float bowl vent hose is plastic and warps due to engine heat. When this get's really bad it can block off the air flow completely, creating a vacuum in the float bowl. To avoid this, throw nasty plastic filter into bin and replace with a small metal-bodied fuel filter, which will not warp.
And another thing - actually I'll stop there 'cause I'm sure I just heard somebody snoring!
PostPosted: Thu May 04, 2017 10:39 pm    Post subject: Reply with quote
All good info Jonny Wink
PostPosted: Fri May 05, 2017 10:32 am    Post subject: Reply with quote
intrigued to hear that the fuel pump is vacuum operated, as mine runs as soon as I turn the ignition key on.............
All will be revealed next week when it goes in for it's carbs fettling.
PostPosted: Fri May 05, 2017 10:52 am    Post subject: SB6R Reply with quote
GeeKay, sounds like somebody has addressed the fuel pump issue by replacing the vacuum-operated original item with an electric one. Intrigued to know where they fitted it, as there's not a lot of space under there, other than in the air box. Whether they replaced it because they were suffering fuel starvation, or because they decided that if Bimota fitted one in the first place, it must have a useful function - I guess we'll never know, unless you're still in touch with whoever put it in?
Chuckie, I know the issues that the 6 air box has, but I'm sure I remember Daz of Melted Sliders say that he'd concluded that the air box on his 6R was too small, so he'd made a bigger one out of carbon, albeit he'd had to raise the tank a bit to accommodate.
Gavin944888
PostPosted: Fri May 05, 2017 12:29 pm    Post subject: My DB9 Reply with quote
Now that I have discovered how to drive the photograph thingy on this forum
...here you go.
bimota visit 089 by Gavin Robertson, on Flickr
This is an Altered and modified DB9....
it has a DB11 rear end to accommodate the larger framed individual...as my
old mother used to say...Big Boned...bless!
bimota visit 096 by Gavin Robertson, on Flickr
In addition..it has Matris front fork conversion and (now) the Ohlins from the
DB7.....also there is the Factory ARROWS exhaust which has been
assembled by Virgins and Kiss-Welded by Angels....(so the invoice seemed
to indicate!)
regards
Gavin
Cagiva Elefant 999r engined
Cagiva BIMOTA Motard Concept
BIMOTA DB11 VLX Supercharger
PostPosted: Sun Jun 18, 2017 9:27 am    Post subject: Reply with quote
Here's my latest:
PostPosted: Sun Jun 18, 2017 11:01 am    Post subject: Reply with quote
Nice. Where did you pick that one up?
arsenic
PostPosted: Sun Jun 18, 2017 3:19 pm    Post subject: Reply with quote
Wow Gavin !
Your DB9 is amazing, i'd love to have one, one day !
here's mine :
Falcolion
PostPosted: Mon Jun 19, 2017 4:38 am    Post subject: Reply with quote
Arsenic,
You got beautiful collection of Italian beauties. Is that KTM 660 in the picture as well?
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega
arsenic
PostPosted: Mon Jun 19, 2017 1:08 pm    Post subject: Reply with quote
Thanks !
And it's a 530 EXC, the 660 stand for a 660cc big bore kit that I wanted to put in, unfortunately with the dollar (us) become stronger with the trump election, it became too expensive, so I've decided to put a 590cc on it instead with a whole work on the cylinder head etc.
The ktm is actually in the garage of the guy who make that possible, it should give more than 71 hp at the wheel wich is pretty great when you compare to the stock 56hp at the crank ^^
But I'm not sure if I want to keep it, I really want a DB10 and there's one in Italy right now... so, I'll see Smile
PostPosted: Thu Jun 22, 2017 9:21 am    Post subject: Reply with quote
behaving itself, at last............
Number2
PostPosted: Fri Jul 07, 2017 1:55 am    Post subject: Reply with quote
why am I getting this message when I try to load a picture?
/usr/users1/tolerant/uploads/bimotaforum/images/ doesn't exist
PostPosted: Fri Jul 07, 2017 11:01 am    Post subject: Reply with quote
Best thing to do is use flickr, photobucket , or something similar to host the picture then get the URL address and paste into forum message.
Don't think forum hosting has been fixed after last time website crashed.
arsenic
PostPosted: Fri Jul 07, 2017 12:58 pm    Post subject: Reply with quote
I use hostingpics.
Pretty easy to use !
Kevmcdo
PostPosted: Sat Aug 05, 2017 6:13 pm    Post subject: Reply with quote
[img][/img][/url]
Page 32 of 37
