Weed
Posted: Fri Aug 11, 2017 1:48 am Post subject: |
Head for the hills. The CX has been on the dyno.
Posted: Fri Aug 11, 2017 7:54 am Post subject: |
The beast is alive , sing little birdie
Cheers Trev |
Posted: Fri Aug 11, 2017 9:13 pm Post subject: |
What's going on with that dip up the top end? |
Weed
Posted: Fri Aug 11, 2017 11:04 pm Post subject: |
It's a 2 stroke is the most logical explanation I've been given so far.
We dropped the needle 1 notch for the blue run as she was running rich, but I didn't have any other main jets to try. That's the next plan |
Posted: Sat Aug 12, 2017 10:10 pm Post subject: |
Weed wrote: |
It's a 2 stroke is the most logical explanation I've been given so far. |
Sounds about right! Do they have a powerjet circuit or a powervalve that cuts in at the top? |
Weed
Posted: Sun Aug 13, 2017 12:28 pm Post subject: |
Yes mate. The power valve comes in at about 8K revs. Nothing fancy just a straight solenoid activation that gives you all or nothing. |
Admin Site Admin
Posted: Sun Sep 03, 2017 8:20 pm Post subject: |
The 2nd kick at around 11k is noticeable when riding it.
The power valve is quite a nice system. It is a bit like a cross between the Yamaha YPVS system used on the RD350 and the like, and the Honda ATAC system. Is is a barrel that rotates, lowering or raising the exhaust port. But when it is in the closed / low revs position the cutout in the rotating barrel has rotated enough to uncover a chamber above the exhaust port.
Katy |
Weed
Posted: Tue Sep 12, 2017 3:00 pm Post subject: |
Yes Katy, it is a fun bike
Cheers |
Posted: Wed Feb 14, 2018 12:31 am Post subject: |
UNIT 5 Motos (That 2 Bims sourced his DT125R from) imported a blue CX125 from France back in Jan. Don't know if it was sourced to order but obviously they have their contacts!! _________________ Not as many bikes as I would like and already too many to keep up with! |
Admin Site Admin
Posted: Wed Feb 14, 2018 12:12 pm Post subject: |
That one has been on Ebay. Quite low mileage
Katy |
Admin Site Admin
Posted: Thu Mar 29, 2018 6:27 pm Post subject: |
Hiya
Some might remember the CX rolling chassis at the Manchester bike show last year.
I have had a few plays with it since. I stuck and engine in it, and a few other bits:-
Decided to have a bit more of a play.
I have put a wiring loom on it. The loom is a bit of a mess having been badly chopped around by a previous owner. Often it seems for no apparent reason (eg, they cut the wires to the regulator / rectifier about 6" from the end, and they are just individual spade connectors so no reason to chop them off). I have had a bit of a session repairing the loom. Now fitted. My aim is to have the dash lights working, and maybe get the bike to start and run. Never going back on the road so not worried about it being reliable to ride.
I do have a better loom, but don't want to waste a good loom on this chassis!
One of the bits cut off was the connectors for the l/h switchgear (replaced with chocolate block connectors). Fortunately they used standard Molex connectors so relatively easily sourced.
Connected a battery up crudely and with a bit of fiddling most of the dashboard lights came on. Petrol level light turns on / off when that sensor is shorted out / not shorted out. Same for the oil warning level.
Connectors to the dashboard are a bit dodgy and not sure where to source those from.
However the rear right hand indicator wouldn't work. Turns out to be a broken wire in the loom. Ordered some wire of the right colour and will solder that in, then tape the loom up again.
Also had a session bleeding the front brake through. This was stripped and painted for the show last year, but I never put any fluid in it. Fluid now added and it works. Bit of a pain to do the brakes. The fluid reservoir is tiny, and you can barely get at the caliper with the wheel in place (you cannot remove the caliper without removing the front wheel first). But at least having a working brake makes it easier to stop when pushing it around.
I do need to sort out the front bracket that hold the clocks. I have this chassis plus another (which will go back on the road) and I have 3 spare brackets for the clocks, but all 3 are a mess (one very badly welded when repaired, and 2 bent, one very badly and the other which seems to want to brake rather than bend back to shape). Might speak to the guy who welded a couple of brackets on the frame last year and see what he can do.
Getting there.
Katy |
Posted: Thu Mar 29, 2018 7:50 pm Post subject: |
welshlamb wrote: |
UNIT 5 Motos (That 2 Bims sourced his DT125R from) imported a blue CX125 from France back in Jan. Don't know if it was sourced to order but obviously they have their contacts!! |
still for sale....theyre asking a lot for it...sure its rare...but so are spares and knowledge to sort it....frightens people more than a Bimota front sprocket change |
Posted: Thu Mar 29, 2018 7:53 pm Post subject: |
I want to see the dash working Katy....me likes pretty lights....if PS facebook folk cant help with the connecter....lawd knows who can.....Found my DB1 indicators yet??? You were my last hope in identifying a donor model/manufacturer.... |
Admin Site Admin
Posted: Thu Mar 29, 2018 9:16 pm Post subject: |
Some bits are easy enough (rear indicators), some a nightmare (bodywork is very difficult unless you want GRP copies, and even then the postage from the USA is not cheap). Engine not bad.
They are a complete git to work on as just about anything requires removing the bodywork (ALL the bodywork), and it is not easy to remove.
The one at Unit 5 is up for £2895, but isn't registered and needs a tidy up.
Suspect the electrical connectors are common in some automotive circles. Probably shared with some Italian cars. I have a sent a message to a friend who works for a company making automotive connectors. If I am lucky he will recognise them.
With luck will spot the indicators, but I am not holding my breath.
Katy |
Posted: Fri Mar 30, 2018 7:05 pm Post subject: |
Now down to £2695......methinks still pricey though for possible untold horrors beneath
https://www.ebay.co.uk/itm/273125926570?ul_noapp=true
Unit 5 do take offers on their bikes....but I'd be offering a grand at best.... |
