YB10 oil filter
daward
PostPosted: Mon Jun 11, 2018 8:01 pm    Post subject: YB10 oil filter Reply with quote
Getting to know the new YB10, so quick oil change thinks I...
Apologies if it's a daft question, but although the filter is a cartridge unit in a nice screw on housing, every listing I can find for a part is like this:
http://www.hiflofiltro.com/catalogue/model/3520
To further add to the confusion when I removed the drain plug a spring and 2 end caps leapt out - what's that all about?
David
PostPosted: Mon Jun 11, 2018 8:04 pm    Post subject: Reply with quote
Generally with Bimota's you find that suppliers find one match and then label all models the same.
For engine parts I would stick to the donor bike search .
Admin
Site Admin
PostPosted: Mon Jun 11, 2018 11:07 pm    Post subject: Reply with quote
The Dieci normally uses the early FZR1000 ExUP engine which has the filter you describe. Think shortly after that Yamaha switched to the spin on canister filters which probably confuses things
Make sure what you are undo8ng is actually the drain bolt!
Katy
PostPosted: Tue Jun 12, 2018 12:49 am    Post subject: Re: YB10 oil filter Reply with quote
David
Are you sure it's the drain plug? I don't know anything about YB's but that sounds like it may be the relief valve?
daward
PostPosted: Tue Jun 12, 2018 10:13 am    Post subject: Reply with quote
Filter sorted thanks - on the way.
I did wonder about relief valve/schoolboy error 😱 but I couldnt find another plug...
I’ll just have to get things back in in the correct order...
Admin
Site Admin
PostPosted: Tue Jun 12, 2018 10:20 am    Post subject: Reply with quote
Hiya
I did the same when I first changed the oil!
From memory the actual drain bolt is further forward.
Katy
PostPosted: Tue Jun 12, 2018 10:37 am    Post subject: Reply with quote
Glad you got it sorted mate
daward
PostPosted: Tue Jun 12, 2018 5:54 pm    Post subject: Reply with quote
Fooled by a cross head screw! Embarassed
PostPosted: Wed Jun 13, 2018 12:17 am    Post subject: Reply with quote
I've been fooled by all kinds Rolling Eyes
