Posted: Mon Jul 16, 2018 9:05 pm Post subject: SB6R swing arm bearings |
what the hell is all this about?
how unlike Bimota to complicate things.............. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Tue Jul 17, 2018 12:33 am Post subject: |
Yep looks complicated. Maybe one bearing for axial load and the other for radial load? Never seen it before though.
Or maybe they just stuffed things in there to make up the space _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Tue Jul 17, 2018 7:32 am Post subject: |
Looks like what it is....someones cobbled something together to try to get the short needle roller bearings to work.....
PDF spares brochure shows how it should be
Needle roller bearing...one on each side....dust cover and a bush a sleeve and a shaft
https://www.bimota-parts.de/images/PDF/sb6r.pdf |
Posted: Tue Jul 17, 2018 7:35 am Post subject: |
Posted: Tue Jul 17, 2018 2:04 pm Post subject: |
they look very much like that, Boris - thanks. But not as shown in the spare parts book. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Tue Jul 17, 2018 9:20 pm Post subject: |
That bearing is for the VDue race swingarm so it could be a later use / version. Youd need to check the overall sizes to if it would fit _________________ Don't read everything you believe |
Posted: Wed Jul 18, 2018 12:08 am Post subject: |
Yep _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Wed Jul 18, 2018 7:35 am Post subject: |
Evilchicken0 wrote: |
That bearing is for the VDue race swingarm so it could be a later use / version. Youd need to check the overall sizes to if it would fit |
I must have the later swing arm then - bearings on their way.
Great info, as always, Boris - thanks. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Wed Jul 18, 2018 8:03 am Post subject: |
GeeKay wrote: |
Great info, as always, Boris - thanks. |
Yay I got lucky _________________ Don't read everything you believe |
