1995 SB6 fuel petcock
Geauxvegan
PostPosted: Thu Jul 27, 2017 9:12 pm    Post subject: 1995 SB6 fuel petcock Reply with quote
Finally got the SB6 I bought a few years ago running but the petcock is leaking. I am hoping to find a rebuild kit for it but I don't know what bike this one is from, assuming it's not an actual Bimota part. It is not a GSXR1100 petcock, at least not for any year model i could find. I tried the search function here and at Classic Bimota Parts but haven't found anything.
Travis
PostPosted: Thu Jul 27, 2017 11:08 pm    Post subject: SB6 Petcock Reply with quote
If it's the electric one that is on the 6R, I doubt you'll find a re-build kit, but all you need to do is to take it to pieces and replace the O ring seals and a fibre washer.
PostPosted: Fri Jul 28, 2017 7:12 am    Post subject: Reply with quote
The SB6 has a vacuum fuel tap. You could try to or open it up and see if its an o ring that's gone or try a Pingle to replace it
Geauxvegan
PostPosted: Tue Jul 17, 2018 2:07 am    Post subject: Reply with quote
My issue was the vacuum diaphragm was cracked. Someone on a US club racing forum pointed me to npr-carbs.co.uk , very clunky website but they have this: http://www.nrp-carbs.co.uk/shop/index.php?route=product/product&product_id=4228
I ordered one, waiting on it to come across the pond.
Geauxvegan
PostPosted: Fri Apr 12, 2019 6:34 pm    Post subject: Reply with quote
Update for internet time travelers with SB6 petcock issues: The rebuild kit from npr-carbs.co.uk arrived in about 3 weeks and is a perfect fit. 10/10 recommended.
PostPosted: Fri Apr 12, 2019 7:44 pm    Post subject: Reply with quote
Good to know
Gammaboy
PostPosted: Mon Apr 15, 2019 2:01 am    Post subject: Reply with quote
Mine didn't have a tap fitted, it has some kind of disconnect. I'm going to modify a eBay SV650 tap to dual outlet to suit.
PostPosted: Mon Apr 15, 2019 5:03 am    Post subject: Reply with quote
FYI....
This is the stock vacuum petcock
And in true Bimota form, the female coupler between the tank fitting and the petcock is 1/2 left hand thread and 1/2 right hand thread Shocked Shocked
PostPosted: Mon Apr 15, 2019 4:40 pm    Post subject: Reply with quote
FYI....
Isn't that so you can hold the tap in the right position and just do up the nut Idea
PostPosted: Mon Apr 15, 2019 8:10 pm    Post subject: SB6 Fuel Tap Reply with quote
No, that's so you can swing both ways Shocked
PostPosted: Mon Apr 15, 2019 8:41 pm    Post subject: Reply with quote
Evilchicken0 wrote:
FYI....
Yeah i’d say that was the thought behind it. Seems like a lot of trouble to go to though
PostPosted: Tue Apr 16, 2019 2:10 pm    Post subject: Reply with quote
Evilchicken0 wrote:
FYI....
Its a Bimota
PostPosted: Tue Apr 16, 2019 2:11 pm    Post subject: Re: SB6 Fuel Tap Reply with quote
Something you wish to share with the group Jonny ????
Very Happy
PostPosted: Tue Apr 16, 2019 3:55 pm    Post subject: SB6 Fuel Petcock Reply with quote
What I get up to in the privacy of my own garage Chuckie, is between me and the vernier calipers Embarassed
PostPosted: Wed Apr 17, 2019 5:19 pm    Post subject: Re: SB6 Fuel Petcock Reply with quote
Fair comment - I tend to use a headtorch as well
