1978 Bimota SB 2 "Evolution" on e-Bay
250GTLusso
PostPosted: Tue Sep 11, 2018 11:23 pm    Post subject: 1978 Bimota SB 2 "Evolution" on e-Bay Reply with quote
I was trolling e-Bay today and came across this interesting listing.
https://www.ebay.com/itm/1978-Bimota-SB-2-Evolution/183424115976?hash=item2ab4ede508:g:u0kAAOSwjuFblOsN
Says its a 1978 Bimota SB 2 Evolution, although there does not appear to be much SB2 left. Maybe someone found one of the "destroyed" frames, and resurrected it? No mention of the serial number of the frame.
Seller appears to be in the Netherlands.
Anyone on here know about this bike?
Cheers,
250GTLusso
1978 Bimota SB2 00046
1978 Bimota SB2 W20089
1982 Bimota KB2 Laser TT 00090
1983 Bimota KB2 Laser S 00138
PostPosted: Thu Sep 13, 2018 11:24 am    Post subject: Reply with quote
Advert does say in the details "frame no. 0000068"....which sort of ties in with the SB2 number sequencing
http://www.bimota.ch/register/register_bimota_sb_en.html
250GTLusso
PostPosted: Fri Sep 14, 2018 3:59 am    Post subject: Reply with quote
Thanks 2bims, I totally missed that. Well SB200068 it is. Its an interesting evolution of the SB2.
PostPosted: Fri Sep 14, 2018 7:17 pm    Post subject: Evolution Reply with quote
As i read this the seller isn’t claiming this as any sort of official model. He says he had an SB2 but when he recommissioned i after lay up he mad e some mods to it. should be easy to check if he still has the original parts (which would back this up)
PostPosted: Sat Sep 15, 2018 9:14 am    Post subject: Reply with quote
Theres more piccies here
http://www.bimota.net/home
just click on each link on the left
But if you look here at the original sales brochure....it tells you the various states of a complete bike or kit form you could buy depending on size of your wallet...
http://www.bimotaforum.co.uk/viewtopic.php?t=5571&postdays=0&postorder=asc&start=30
IMHO....someones spent a lot of money to build what it is...without improving on the original in looks or value.......I would have expected a resto thread specially set up on the internet to contain at least one photo of "before" the resto started.....first pictures are of the frame returned from the powder coaters.
As far as originality goes it has the frame and swingarm and footpegs and gear/brake levers of a Bimota....and thats it.....resto thread shows new clocks....different yokes...forks...badly fitted front mudguard not using any of the forks inbuilt lugs, top or bottom....17inch Oscom wheels in lieu of 18inch mag campags...check out the back wheel....1 inch wide alloy "spacer" on the back rear disc side...and what looks like a 3 inch wide alloy spacer on the sprocket/cush drive side to try and acheive chain alignment.....thats a whole lot of "leverage" acting on cush drive bolts in the hub if there is any in there still....
Forks, wheels, brakes, rear shock, clocks, wheels and all bodywork none Bimota.....Also take into account all of that red painted CrMo tubing at the back from the engine frame assembly is "extra".....normal Sb2 frame has self supporting tank/seat unit so is entirely devoid of any steel tubed substructure to support it....heres a "normal" frame
https://l7.alamy.com/zooms/208b837778b24d75a4a746c1e566f228/bimota-sb2-motorbike-with-750-suzuki-motor-in-custom-frame-j2516t.jpg
PostPosted: Sat Sep 15, 2018 10:39 am    Post subject: Reply with quote
I don’t mind it. At least it’s another Bimota that’s been saved / resurrected.
