SB6r low fuel warning light trouble
Horseheed
PostPosted: Tue Oct 16, 2018 8:21 pm    Post subject: SB6r low fuel warning light trouble Reply with quote
Hi all, iam having trouble with my low fuel warning light , it lights up for a few seconds when I switch the ignition on then goes out , even if the tanks full or empty . Has anyone had the same trouble or more importantly does anyone know how I can get it too work Cheers all
Horseheed
Gammaboy
PostPosted: Wed Oct 17, 2018 11:03 pm    Post subject: Reply with quote
Is it not doing that to confirm the bulb works?
Horseheed
PostPosted: Thu Oct 18, 2018 5:16 am    Post subject: Reply with quote
Hi Gammaboy, that's what I thought, I was trying to find out if anyone has had the same trouble and how they cured it Cheers for the reply
Horseheed
O_Roger
PostPosted: Thu Oct 18, 2018 11:16 am    Post subject: Reply with quote
The common fix is to unscrew the bulb. The indicator is, if fully functioning, useless anyways. Just orient yourself on the Km Clock.
My SB6 is good for >160km.
PostPosted: Fri Oct 19, 2018 10:32 am    Post subject: Reply with quote
Reset the trip when you fill up
PostPosted: Fri Oct 19, 2018 11:41 am    Post subject: Reply with quote
+1
SuziEngine2
PostPosted: Sun Dec 16, 2018 12:20 am    Post subject: Re: SB6r low fuel warning light trouble Reply with quote
It's supposed to do that. It runs the fuel pump for the same couple of seconds.
Sorry for late response, been away for a while.
1998 Bimota SB6R
1982 Suzuki GS1100SZ Katana
PostPosted: Mon Dec 17, 2018 10:29 am    Post subject: Reply with quote
my SB6R had a vacuum fuel pump (which I have since removed).
