YB9 Bellaria air filter Fram CA3131. Where can I get one
Kiwi
PostPosted: Tue Dec 11, 2018 5:20 am    Post subject: YB9 Bellaria air filter Fram CA3131. Where can I get one Reply with quote
Hi. Looking for a new air filter. Anyone know where I can source one? Original is a Fram CA3131.
djk
PostPosted: Tue Dec 11, 2018 9:14 am    Post subject: Reply with quote
Is that the bike with an interesting paint scheme from Pat?
I had trouble sourcing a filter for my YB11 which should use the same one and my mechanic modified a filter from a Hyosung 250 to fit, i don't think it was an exact fit but it didn't need much modifying from memory.
PostPosted: Tue Dec 11, 2018 9:18 am    Post subject: Reply with quote
Not familiar with Bellaria….but a quick Google search comes up with alternatives
Fram CA3131
https://www.yoyopart.com/oem/7178827/fram-ca3131.html#interchange
Seems to be saying Austin Allergro and Austin Maxi from the 1970's onwards...But evidently check for sizes/shape etc
https://shop.aseriesspares.co.uk/shop/air-filters/replacement-air-filters/austin-allegro-1-0-1-3-unipart-fram-air-filter/
This site has dimensions that you could check against....again it lists Austin allegro and Maxi cars
http://www.niparts.com/MAC/14D684/FRAM/CA3131.html
Oval/Lozenge shaped filter as per spare parts brochure??
https://www.sfogliami.it/flip.asp?sc=figj256o34mky7ea0uc5rokhshvqi7ej&ID=117651#page/34
PostPosted: Thu Dec 13, 2018 6:43 am    Post subject: Reply with quote
Hi Kiwi, welcome!
Are you by chance on the exup forum?
Kiwi
PostPosted: Wed Dec 19, 2018 5:23 am    Post subject: YB9 airfilter Reply with quote
Hi all. Thanks for input. Found one.
DJK, yes it’s the ugly paint one from pat. Much better looking in real than buy photo.
WHO, no I’m not on the echo forumn.
Cheers all.
PostPosted: Wed Dec 19, 2018 10:54 am    Post subject: Reply with quote
Dont keep it secret....what link or part number worked? where did you find one? Share and share a-like
Kiwi
PostPosted: Fri Dec 21, 2018 3:27 am    Post subject: Reply with quote
Sorry for neglecting to say folks, but sourced a Fram 3131 air filter fro Bimota Classic parts Italy
PostPosted: Fri Dec 21, 2018 10:44 am    Post subject: Reply with quote
Ah good Old Paulo Girotti of Bimota Classic Parts....pricey...and post is also...but often the ONLY choice available....it is good to keep these wonderful machines on the road though...I'm just fortunate that all of my Bimotas DONT have specific aged air filters that aren't available...Most can utilise Air Ram filter mesh sheets just cut to size....and the odd one uses K&N cones
MJ146
PostPosted: Tue Sep 19, 2023 7:01 am    Post subject: Reply with quote
I recently tried to find an air filter for a Bellaria, here in the UK.
(as I expected there to be parts for Austin Maxis and Allegros etc in the UK)
No luck whatsoever, until Bimota Classic Parts came to the rescue!
PostPosted: Fri Oct 13, 2023 10:10 am    Post subject: YB air filters Reply with quote
I have a small NOS stash of these. £30 + p&p.
MJ146
PostPosted: Wed Feb 14, 2024 7:27 am    Post subject: Re: YB air filters Reply with quote
Thank you Jonny!
