Rich
Joined: 02 Dec 2008 Posts: 14 Location: Queensland Australia
Posted: Sun Jan 16, 2011 9:15 am Post subject: Electronic Gauges |
Hi Everyone, The electronic gauges on my 1997 YB11(But I think common to a few models) have died. The speedo went haywire first then the tacho stopped about an hour after. Is this a common problem with an easy fix? or do I need professional help. Thanks Rich C. |
Posted: Mon Jan 17, 2011 7:25 am Post subject: |
Hi Rich
Yep, fairly common problem but not an easy fix unless your an electronics wiz.
Even when they are working they are wildly in-accurate |
Rich
Posted: Mon Jan 17, 2011 7:33 am Post subject: |
Thanks Oily. I thought as much but was hoping anyway. I know what you mean re accuracy, but officer...the speedo said I was only doing 100. Rich. |
Posted: Mon Jan 17, 2011 10:08 am Post subject: |
Hi Rich
I run a SPA programable clock in mine as my clocks went the same way. Its not the cheapest to put in but looks good in a carbon fibre mounting I made and is bang on accurate when matched to my satnav Nige |
Rich
Posted: Mon Jan 17, 2011 10:55 am Post subject: |
Hi Nige, Would love to see a photo of your set up, I guess I will be doing something similar. Thanks Rich |
Posted: Mon Jan 17, 2011 4:54 pm Post subject: |
Here's a SPA/carbon dash I built back in the day for my first SB6. Expensive clocks, couldn't afford to build one these days with spa prices
Excellent bit's of kit though
bluedog59
Posted: Tue Jan 18, 2011 12:11 am Post subject: |
It's not just the electric speedos that are inaccurate. I think the factory "tuning" on the YB10 amounts to moving the numbers around the dial a bit. |
Posted: Tue Jan 18, 2011 12:59 am Post subject: |
Why not use a Koso dash - they supply the dashes for the DB7 _________________ Don't read everything you believe |
Rich
Posted: Tue Jan 18, 2011 8:39 am Post subject: |
Thanks for the tip Evilchicken, have just ordered one to fit up... Great....Rich |
Rich
Posted: Sat Feb 12, 2011 10:39 am Post subject: |
when I try to view the picture it tells me that it has been removed? |
Rich
Posted: Sat Feb 12, 2011 1:33 pm Post subject: |
Click the img button then past the "direct link" and then click img button again.
Looks good - I'd paint the inside of the fairing satin black but that's just me _________________ Don't read everything you believe |
