Spongebob
Posted: Sun Apr 14, 2019 3:41 pm Post subject: Tuatara (also other YB6?) Front brake Master Cylinder |
Anyone know what model Yamaha they robbed for the front brake master cylinder? Mine's seized solid and every model year of the FZR1000 seems to have a different part numbered master cylinder. The piston/seal/repair kits are all different part numbers too. There is no identification on it other that 8430 stamped on the side which doesnt align to any part number i can find. |
Posted: Sun Apr 14, 2019 5:46 pm Post subject: |
Have you tried looking in the spare parts manual for the part code number??….Bimota didn't try to reinvent the wheel....if it was a Bimota specific part...it had a bimota specific code/part number...similarly if it was another manufacturer...be it Ducati etc...they "tried" to use the same part number that those manufacturers used..... |
Spongebob
Posted: Sun Apr 14, 2019 6:01 pm Post subject: |
Just been looking at Yamaha parts diagrams for different model years of the FZR1000. It’s very definitely a Yamaha part as it bears the legend YAMAHA across the lid. I have not looked at the Bimota parts books yet though. |
fish
Posted: Mon Apr 15, 2019 12:08 am Post subject: |
Hi I would pull a part and measure bore size and go from there cheers craig _________________ DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy |
Posted: Wed Apr 17, 2019 10:08 am Post subject: |
1988 FZR1000.
Spongebob
Posted: Wed Apr 17, 2019 10:58 am Post subject: |
Having got the thing apart the issue is the age of the fluid. It’s obviously absorbed water and turn crystalline particularly around the piston which has seized it solid. I’ve run all the parts through the ultrasonic cleaner and now rebuilt everything and it’s working fine.
I might just fit a Brembo master cylinder I have in the SB6 hoard as the brakes are wooden and consign the original to my box of OEM parts to preserve originality if any future owners want that. |
Posted: Wed Apr 17, 2019 11:25 am Post subject: |
They are not a great master-cylinder, always a bit spongy no matter how well rebuilt-bleed. Put a good one away for bike providence, but brembo, R6 R1 will pull you up better. |
Spongebob
Posted: Mon Apr 22, 2019 11:41 am Post subject: |
Brembo master cylinder fitted and bled. Nice firm lever and the reservoir is at the right angle. Now on to the next job of trying to work out why i have no neutral or oil light. |
