Best Free SD Card Recovery Software for Windows?
Kassia
PostPosted: Fri Aug 23, 2019 4:36 am    Post subject: Best Free SD Card Recovery Software for Windows? Reply with quote
1. What is the best free SD Card Recovery Software for Windows?
Bitwar Data Recovery software will retrieve the data of mostly all types.
A friendly interface will make the whole recovering process easy and comfortable. You can use the powerful preview function to check the exact right file you want to restore.
Competitive price. We often have to pay so much time and money to send your computer or SD card to repairing agencies. They have professional software to recover data. Usually, Technicians have this Bitwar Computer Repair Software.
2. What is the matter about SD card losing data in Windows system?
Deleted - Delete all files from SD card;
Shift + Delete- Click "Shift + Delete" to remove all data, and they will not go to the recycle bin;
Corrupted SD card;
Formatted SD Card;
SD card shows 0 bytes (RAW).
3. Are you still not make up your mind for which software to choose?
We want to recommend you this professional data recovery software---Bitwar Data Recovery Software. To see is to believe, all our losing data can retrieve in a preview show. You can make your decision after everything is clear for you. You can recover almost all types of files, including photos, videos, audios, documents, emails, etc. from various storage devices, such as USB flash disk, SD memory card, portable digital cameras, and others.
Step 1: Launch Bitwar Data Recovery software with standard mode, and you will see there are 6 recovery modes on the standard modem, please choose a recovery mode here.
Step 2: Please ensure that your SD card has connected with your PC. All memory card is supported by Bitwar Data Recovery if you just connect it to your PC with a card reader. Select it and hit on the button “Next.”
We know that Bitwar Data Recovery supports all file types to recover. In order to save scan time, however, I suggest you select the file types to which the file belongs. Then click "Scan."
Step 3: After the scan is over, please locate files you want by Type, Path or Time, and you can preview the file thumbnail to make a selective recovery.
Then select the file you want and click “Recover” button to save them. Notice that doesn't restore data back on the SD Card. Find another safe storage space for your retrieve data.
4. With Bitwar Data Recovery, you can get back your precious memory:
Important files that you’ve lost on your memory card for unknown reasons
Files that you’ve accidentally or intentionally deleted
Files corrupted due to hardware error
Documents lost after formatting or Factory Reset
Loss data due to viruses attack
Drive Error with RAW format
No matter what type of data you lose, no matter what type of device you are using, only if your memory card is not physically damaged completely, your data has its chance to come back. Bitwar Data Recovery
