Posted: Thu Apr 16, 2020 7:33 pm Post subject: |
Gammaboy wrote: |
djk wrote: |
A thin piece of wood under the front tyre, i'll have to remember that next time i am trying to get the fairing of the SB7. Can't use a stand and i have no rafters to suspend the bike from. I did try a ladder once and suspended the bike in between but it didn't leave me much room to do anything. Every time i pull that fairing apart i dread doing it. |
I've welded an old front axle to a car stand so I can lift the front of my SB6 on the headstock lifter, drop the wheel out, fit stand, remove head lifter, remove/fit fairing... |
I need a picture of that....how do you get the fairing past the Front axle from a car???????????....WOrds aren't sufficient here....its pictures we need....always looking to reinvent the wheel as regards Bimota clamshell one piece fairing removals..... |
Posted: Thu Apr 16, 2020 9:34 pm Post subject: |
Gammaboy wrote: |
djk wrote: |
Now that is an ingenious idea |
Gammaboy wrote: |
djk wrote: |
Posted: Thu Apr 16, 2020 9:51 pm Post subject: |
So another sunny day in Blighty and a few hours to spare.
YB got a quick check over, oil and filter actually look reasonably new, well filter a few years old by the looks of it and oil still slightly translucent not black. Air filter clean and not falling apart Things are looking up !!
Battery attached and fuel added .
Ignition on and dash lights up !! Could be onto a winner here !!
Hmmm , whats that smell ?? Ah leaking fuel out of the reserve solenoid , Hmmm , only a slight weep , lets continue .
Starter pressed and engine starts to whirl , and whirl , and still whirlling !!! . Drop of fuel in the bell mouths and engine sputters !!
OK , fuel issue it is . 10 minutes later has the tank off, fuel relay activating , but pump not pumping
Current to pump checked , OK , pump wired directly to 12v , still nothing . Another 10 minutes has the pump off and Ah !!! Think this might be the problem !!
Quick clean up of the contacts , 12v connected and there she blows !!
Pump reinstalled , slave fuel tank connected and SHE LIVES !!!!
Bit rough at first but after a few minutes is ticking over nicely !!! Think a good service and a carb clean/balance will have it singing again !!
Time for a deep clean and sorting that leaking tank !! |
Posted: Fri Apr 17, 2020 5:23 am Post subject: |
Whats the "reserve solenoid"?....has it got one of those bimota curiosities whereby when it hits "reserve" a light comes on and you have to press a switch to activate it and then it accesses the reserve element in the tank?....When I was working on Pauls YB9SR.....it had a grey flick switch down low RHS behind tank....but no indication what was "on" or "off".....
Pump on his worked for a while....after bike had been dry stored for a while.....then it stopped clicking....would still run with it disconnected and fuel bi-passed so just on gravity....but wouldn't rev out at higher revs......insufficient flow at top end....and that was when just stood still...I'd imagine it would be worse if ridden and under load.....Seals had gone on the pump and it was a "sealed" unit....refused to tick after a while to build pressure and flow....so new one was acquired and fitted....all good after that....Those contacts and gunk inside the cap.....yuk.....heres hoping the rest of the electrics weren't similarly tied to the titanics anchor when she went down....Running though and idling....thats good.....all other electrics fine?
The YB9 also had nice clean and clear engine oil and brake fluids and fresh looking filter so they were left alone.....I did drain off the coolant and flush through though....water pump and impeller etc were a bit blocked......and bleed holes and bolts in cylinder casings needed a few runs through with a hose to get them to run clear......A few tiny bolts on the casings to pull and bleed off.....sort of the same as on the YB11 ….so look at the Workshop manual and that helps you source the couple of bolts to pull to drain the cylinders...worth pulling the water pump casing also to clean out the casing and check impeller and thermostat in there....but I guess you'll be doing that also....Horn Honking....indicators winking etc?
KDX MOT today...or rather in 3 hrs time.....He finally escaped from a V long holiday in Tenerife......poor beggar had to pay for 4 flights home before the last flight WASNT cancelled by the airline....and the swines of the first 3 flights wouldn't take a credit card payment....cash or direct debit card only....and yes...he's still waiting for a refund....and cant charge back as they wouldn't take a credit card.....all that and they flew him to Gatwick from where he had to hire a car one way to get back to Madchester....He's operating on a 8.30 to 2pm 5 day week....but business picking up as Main dealers are all shut so people are shopping locally to get their cars serviced and MOT'd......How about your MOT man? |
Posted: Fri Apr 17, 2020 6:36 pm Post subject: |
2bims wrote: |
Whats the "reserve solenoid"?....has it got one of those bimota curiosities whereby when it hits "reserve" a light comes on and you have to press a switch to activate it and then it accesses the reserve element in the tank?.... |
The single red light on the clock binnacle is actually a button/light. Tank has 2 fuel taps on it, a manual on that is on or off , always set to on, and an electrical one that is the reserve and actuated by the switch/light.
Posted: Fri Apr 17, 2020 8:24 pm Post subject: 8e |
Quite right Vort. That switch on the dash is fragile (best covered when washing) & now unobtainium. _________________ What, Jonny's gone! |
Posted: Fri May 01, 2020 8:51 am Post subject: |
Moisture certainly is like cancer to electrical connections and components. Hopefully the fuel pump holds up. The fuel reserve setup seems over complicated for what it does _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
nichosk
Joined: 07 Nov 2012 Posts: 15 Location: United Kingdom
Posted: Fri May 01, 2020 9:36 am Post subject: |
Just in case.....the Fuel pump on my YB8 failed recently but was bought back to life with a repair kit, about 15 quid I think 👍 |
Posted: Fri May 01, 2020 9:46 am Post subject: |
Yamaha fuel repair kit from Fowlers?i wasn't sure if it was a serviceable item? I presume it was the rubber seals in the pump that were knackered? |
Posted: Fri May 01, 2020 9:34 pm Post subject: |
The contacts in the fuel pump stick sometimes, and the pump stops working. Usually a whack with a hammer fixes it. |
nichosk
Posted: Sat May 02, 2020 8:43 pm Post subject: |
Sadly the 'Drop Test' didn't fix it so it was a points repair kit that did the job |
