SB6R Starter Solenoid connections
Chrissb6
PostPosted: Tue May 05, 2020 9:47 pm    Post subject: SB6R Starter Solenoid connections Reply with quote
Hi Guy's help needed again Rolling Eyes
Having disconnected and re terminated the connections to the starter motor solenoid I'm no faced with a starter motor that won't turn, starter motor works fine but the primary start circuit is not pulling in the solenoid. Having tried with no luck to find a diagram or picture on the my net my question is, has anybody on here got a picture of the wiring connection - terminations of the solenoid or a diagram l can follow.
Help much appreciated
Regards
Chris
Live for the Moment
PostPosted: Wed May 06, 2020 7:31 am    Post subject: Reply with quote
Do you have the Owners Handbook?...normally the wiring diagram is in the back.....Do you do FB?....
PostPosted: Wed May 06, 2020 10:02 am    Post subject: 6R solenoid Reply with quote
Holding the solenoid with the main terminals at the front, the cable from the positive terminal of the battery connects to the right hand terminal. Immediately behind that goes the green wire and behind that the orange wire. On the left, immediately behind the cable to the starter goes the black wire. The 4th terminal in the connector block is not used. I assume you’ve replaced the solenoid, as newer ones are wired differently to the originals and the wiring diagram is not much help here, as it only shows 2 wires marked L (lilac?) and RW (red & white?). Make sure you’ve got a good fuse in there.
Chrissb6
PostPosted: Wed May 06, 2020 10:39 am    Post subject: Re: 6R solenoid Reply with quote
Jonny l owe you a beer mate many thanks for that, l must of had one serious brain fart doing mine back up. And to think l always say to folks before you start, take a pic take a pic!
Cheers Mate
Live for the Moment
PostPosted: Wed May 06, 2020 2:16 pm    Post subject: 6r solenoid Reply with quote
You’re welcome. Let us know if that works.
Chrissb6
PostPosted: Thu May 07, 2020 8:38 pm    Post subject: Re: 6r solenoid Reply with quote
Sorted Mate cheers
Live for the Moment
