Posted: Sat Jun 13, 2020 10:36 am Post subject: |
Will do Piso👍 _________________ Not as many bikes as I would like and already too many to keep up with! |
Kaindub
Joined: 24 Jul 2016 Posts: 6 Location: Sydney, Australia
Posted: Sun Jun 14, 2020 4:33 pm Post subject: |
I had a similar issue with my YB7. NEEDED THE SEAT bolts.
I found some shouldered bolts on eBay.
These are construction bolts. They have a cap head (hex). Then it goes into a shoulder that is thicker than the thread. I think the shoulder on mine was 20mm but it was the right size for the YB7. Then there is a shortish thread. In my case 16mm.
The bolt length and shoulder come in different lengths.
I had to machine the shoulder a few mm and then I put a taper on the socket head.
The bolts are a few Bucks but way cheaper than Bimota spares. I think I got them on eBay, but any good bolt supplier can supply. Plenty of on line catalogs to find what you need.
Material is hard steel. |
Posted: Mon Jun 15, 2020 9:15 am Post subject: |
couple for me please (1 bike worth!)- be interesting to see how hot they get from heat transfer from the exhausts below! _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Posted: Tue Jun 16, 2020 11:56 am Post subject: |
bimotanige wrote: |
couple for me please (1 bike worth!)- be interesting to see how hot they get from heat transfer from the exhausts below! |
Shouldn't be an issue....they fit into proud sockets with flanges....and....you should have as standard a double layered as heat baffle unit that covers the link pipes |
Posted: Tue Jun 16, 2020 12:06 pm Post subject: |
bimotanige wrote: |
Posted: Thu Jun 18, 2020 5:25 pm Post subject: |
Just to advise, i’ll let this run for the next week and see where we have got to at that point! Thanks for the comments so far. _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Fri Jun 19, 2020 8:17 am Post subject: |
brian wrote: |
2bims wrote: |
brian wrote: |
I have a friend in Aus that makes 'special' bolts, fasteners, spacers etc as a hobby. He mostly use titanium but can use steel, alluminium, titanium etc. He also has the rotary broach to do the in-hex. I'll bounce it off him and see what he could do. |
I've no idea what the rotary broach is Brian....but lets see....I presume you have the same plastic/nylon bolts on your Junior? |
Yep, my Junior has the original plastic fasteners. |
Ok.... so I thought my DB2 J had plastic fasteners.... on closer inspection I’ve found that they are indeed black anodised ALUMINIUM! I’ll post a couple photos in my Junior refresh thread
. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Jaguar
Posted: Mon Jun 29, 2020 2:14 pm Post subject: |
These should be the same as the ones used on the exhaust of a SB8R?
IF so, I would be down for some as well. _________________ Bimota (Tesi 1D 904SR, DB2, DB4, SB6,SB6R, SB8R, SB8K Santa Monica) Ducati (1000SS, Monster S4, 999R) Aprilia (RSV Mille R Haga) Honda (CL125s and 70s Chopper) |
Posted: Mon Jun 29, 2020 2:57 pm Post subject: |
Hi, Im a couple of days behind on this due to other work at the moment around the house! Will post up a dimensioned drawing for you to check. In any case I’ll have to get a quote for a reduced number as not enough takers for the originally discussed batch size. _________________ Not as many bikes as I would like and already too many to keep up with! |
Fly8s
Joined: 13 Feb 2020 Posts: 10 Location: Massachusetts, USA
Posted: Tue Jun 30, 2020 2:56 am Post subject: |
I’ll take a set. Thanks |
Posted: Tue Jun 30, 2020 8:11 am Post subject: |
2bims wrote: |
bimotanige wrote: |
assuming you have standard pipes. _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Posted: Tue Jun 30, 2020 11:39 am Post subject: |
My end cans and down pipe 2into 1 into 2 connecter isnt standard...but still space for the baffle plates....they fit between the seat rails....but...If you have 150mm dia piping then maybe yours went by the wayside |
Posted: Tue Jun 30, 2020 2:31 pm Post subject: |
2bims wrote: |
as I said mine isn't standard and are 2 large diameter pipes - no Y piece. Only 1 layer of the baffle plate will fit and the pipes sit 8mm below it in parallel - that's why it all gets a bit warm when your out on a decent run. _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Posted: Wed Jul 01, 2020 12:48 pm Post subject: |
welshlamb wrote: |
Hi, Im a couple of days behind on this due to other work at the moment around the house! Will post up a dimensioned drawing for you to check. |
here you go Jaguar. (Nb there will be a 1mm 'band' at the base of the screw's head ie the taper isnt the full 4mm depth if that makes sense) _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Wed Jul 01, 2020 12:55 pm Post subject: |
bimotanige wrote: |
.....as I said mine isn't standard and are 2 large diameter pipes - no Y piece. Only 1 layer of the baffle plate will fit and the pipes sit 8mm below it in parallel - that's why it all gets a bit warm when your out on a decent run. |
an aside from the seat bolts but could Zircoflex sheet be your friend here?
https://www.zircotec.com/heat-shield-materials/ _________________ Not as many bikes as I would like and already too many to keep up with! |
