YB10 Dieci front brake pads.
whybeeten
PostPosted: Mon Aug 08, 2011 10:26 am    Post subject: YB10 Dieci front brake pads. Reply with quote
Has anyone got the EBC serial number for the front/rear pads on a Dieci ,or equivalent.
Ta.
Admin
Site Admin
PostPosted: Mon Aug 15, 2011 12:57 pm    Post subject: Reply with quote
Fitment wise I think the calipers are the same as those use on the Ducati 907IE (and other Ducatis of a similar age).
However these had steel disks and the pad material might not work well with the Diecis cast iron disks (I tried EBC HH pads on my Dieci - worked OK in the dry but in the wet the lag was such you could pull the lever and count slowly to 5 before anything happened).
Keith
