Lightweight full exhaust for YB8 ? - maybe thunderace?
bimotadownsouth
PostPosted: Tue Jul 12, 2011 5:39 am    Post subject: Lightweight full exhaust for YB8 ? - maybe thunderace? Reply with quote
Hi anyone know of a lightweight full system exhaust that will fit up to the YB8 ?, maybe something light/modern that fits up to a thunderace ?
if everything is under control - you aint going fast enough
zombie
PostPosted: Tue Jul 12, 2011 7:35 am    Post subject: Reply with quote
Yam Exup 1000 race exhaust might fit??
bimotadownsouth
PostPosted: Tue Jul 12, 2011 9:22 pm    Post subject: Reply with quote
I thought cylinder head changed quite a bit on R1 onward ?
zombie
PostPosted: Tue Jul 12, 2011 11:23 pm    Post subject: Reply with quote
I was thinking of the yam 1000 exup model which YB8 used parts from i.e. twin headlight and predecessor of the Thunderace after the Genesis?
PostPosted: Wed Jul 13, 2011 1:48 pm    Post subject: Reply with quote
Aren't there two models before the ThunderAce ???
The Genesis and the EXUP.
PostPosted: Wed Jul 13, 2011 7:48 pm    Post subject: Reply with quote
"genesis" is early FZR1000 (pre-exup), then you had the FZR1000 exup which had motor revisions and then 2x further versions that were basically cosmetic overhauls only i believe
around 98 the R1 appeared with a revised motor whilst still using the "exup" exhaust technology, its a totally different animal...............
PostPosted: Wed Jul 13, 2011 10:47 pm    Post subject: Reply with quote
The ThunderAce was revised from the EXUP. The R1 is a complete redesign with the gearbox stacked which in turn changed the frame / swingarm architecture
bimotadownsouth
PostPosted: Fri Jul 15, 2011 4:35 am    Post subject: Reply with quote
So would thunderace system fit 1992 exup ?
PostPosted: Fri Jul 15, 2011 10:25 am    Post subject: Reply with quote
I can't really tell you but I doubt it. I know more about 400's (bear with me on this), They had a Genesis, then EXUP then 3TJ, they're similar to the 1000's.
The EXUP pipes will fit onto a 3TJ and vice versa but they burn the bodywork
Maybe you could contact some manufacturers who've been around for a while like Devil, Yoshi, Vance + Hines etc and see if they have any new old stock and/or hang out on a Yamaha forum and ask around there
PostPosted: Fri Jul 22, 2011 12:46 pm    Post subject: Reply with quote
Yb8 runs the same engine as the 3GM FZR1000 sump tilts towards the front. Not sure if the Ace wedges towards the front but wouldn't be surprised as the YZF750 of the same era does also. The earlier Black engined YB's run a different sump and cylinder angle so it is unlikely systems from earlier bikes would suffice.
Be warned those of you who like doing long wheelies on your YB-8's > onwards... They will run out of oil and spin mains Shocked
Admin
Site Admin
PostPosted: Fri Jul 29, 2011 4:25 pm    Post subject: Reply with quote
I would suspect any race exhaust for the FZR1000 EXUP will fit. Thunderace one probably would as well, but probably not for any mounts under the engine and no doubt it would mean the stock silencer would not longer match up to the standard hanger for it.
Keith
PostPosted: Sat Aug 20, 2011 6:35 am    Post subject: Reply with quote
I've always been curious about the difference between the genesis and exup motors. I had always heard about the bank angle differences, but this is not correct.
On proper investigation it turns out the motors are the same in this regard. ie; both have the same cylinder bank angle. So the only difference is the sump, and this is where you will have problems fitting headers not made specifically for the model.
As Edgar Allan Poe said "Believe nothing you hear, and only one half that you see."
Here's the evidence... this long standing myth is busted:
PostPosted: Mon Aug 22, 2011 10:31 am    Post subject: Reply with quote
I bought a thunderace Akrapovic system off these boys.(race £580,road£655) , they list the FZR1000 also.
http://www.classicmechanics.com/news/akrapovic-pipe-dreams
Apparently Akrapovic are re-making a limited run of hertiage systems.
I fitted it to the bike on sunday , but have yet to refit the body work , so if you can tell me with areas of the sump you think are different I will take a picture of the YB11 and Akrapovic exhaust.
Performance parts had about 10 sets of the thunderace one left.
Thing that really got me was that the exhaust silencer hanger even matches up on the YB11 , although I think I may have to mod the body work.
