bimototo
Posted: Sun Jan 22, 2012 7:04 pm Post subject: db4 owner help me please :-) |
hi,
has subjetc, I need a help,
someone have some picture of a monoseat model without a tail?
I need to see how is the frame of that version.
i've buy a monocoque of the "old version" and is not plug and play.......
thanks a lot! _________________
Posted: Sun Jan 22, 2012 9:09 pm Post subject: |
I have a new DB4 rear subframe in the garage - can take a picture if it helps?
Garry. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
bimototo
Posted: Sun Jan 22, 2012 9:24 pm Post subject: |
if is for the db4ie i don't need (alredy have) if is for the other model will help a lot
my email is antonio.cocchi@sick.it _________________
Posted: Sun Jan 22, 2012 9:39 pm Post subject: |
don't know which model its for, Antonio - the box is marked "DB4".
I will take a photo and send it anyway.
bimototo
Posted: Sun Jan 22, 2012 9:57 pm Post subject: |
thanks a lot _________________
Posted: Sun Jan 22, 2012 10:05 pm Post subject: |
Hey Antonio - are you anywhere near Misano Adriatico?
bimototo
Posted: Sun Jan 22, 2012 10:36 pm Post subject: |
i am very close to Imola almost 80km from misano, i've been in bimota factory just a couple of day ago for have lunch with the marketing mng.
why? _________________
Posted: Mon Jan 23, 2012 1:47 pm Post subject: |
Heres a picture of the single seat frame. I have a dual seat frame in the garage. so can put them together for comparison if it helps.
bimototo
Posted: Mon Jan 23, 2012 2:21 pm Post subject: |
it will help a lot
can you please mail me a big size picture?
and also of in not a problem can you send me the measure of that frame vero vrty thanks! _________________
Posted: Wed Jan 25, 2012 2:48 pm Post subject: |
just found mine in the garage and its a 2-seater, so of no help to you. _________________ Bimota SB6 and Benelli TNT 899S road bikes.
Posted: Sun Feb 05, 2012 11:41 am Post subject: |
Had a look at the two frames. It appears the single seat is at a slightly different angle.If you look at the side triangle the top is 240mm the frame side is 130mm and the angle is 260 mm. Will try to get some pictures to show difference. |
bimototo
Posted: Sun Feb 05, 2012 9:20 pm Post subject: |
vort28 wrote: |
thanks a lot, but don't worry,
I found the way to use mine frame, today i've start to move part of the wiring, include cpu and rectifire in the front (I've take out the airbox several year ago),
so stay tuned, I will post some picture _________________
