250GTLusso
Posted: Thu Mar 28, 2019 11:53 pm Post subject: |
Note to Brian - for cleaning metal tanks, don't use nuts/chains/etc inside the tank. Use a product called METAL RESCUE (Available at Home Depot in the US for $25 a gallon - you only need a gallon, although I had so many tanks to do I bought 5 gallons). Put it in the tank, and let it sit for 2 to 24 hours (depending on the level of rust) and drain (its resuable, so I also filter out the rust before I store it in a closed container for the next tank cleaning). Then rinse the tank multiple times with a small quantity of petrol (4 oz) to get all the residual METAL RESCUE out of the tank. I keep rinsing until I do not get any more METAL RESCUE out with the 4oz of petrol (it will not mix with petrol, as its heavier, so it separates out like water. I have used it in numerous steel tanks, and they turn out like new (literally) inside. Amazing stuff. _________________ 1978 Bimota SB2 00046
1978 Bimota SB2 W20089
1982 Bimota KB2 Laser TT 00090
1983 Bimota KB2 Laser S 00138 |
Posted: Fri Mar 29, 2019 12:01 am Post subject: |
250GTLusso wrote: |
Note to Brian - for cleaning metal tanks, don't use nuts/chains/etc inside the tank. Use a product called METAL RESCUE (Available at Home Depot in the US for $25 a gallon - you only need a gallon, although I had so many tanks to do I bought 5 gallons). Put it in the tank, and let it sit for 2 to 24 hours (depending on the level of rust) and drain (its resuable, so I also filter out the rust before I store it in a closed container for the next tank cleaning). Then rinse the tank multiple times with a small quantity of petrol (4 oz) to get all the residual METAL RESCUE out of the tank. I keep rinsing until I do not get any more METAL RESCUE out with the 4oz of petrol (it will not mix with petrol, as its heavier, so it separates out like water. I have used it in numerous steel tanks, and they turn out like new (literally) inside. Amazing stuff. |
Thanks for the info mate. I’ll do some research and see if it’s available in Australia, or if there’s an alternative. Cheers _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Gammaboy
Posted: Fri Mar 29, 2019 12:47 am Post subject: |
brian wrote: |
Thanks for the info mate. I’ll do some research and see if it’s available in Australia, or if there’s an alternative. Cheers |
For steel tanks it's hard to go past phosphoric acid for cleaning/treating rust - it leaves a nice layer of iron phosphate on the steel which helps prevent further corrosion. |
Posted: Fri Mar 29, 2019 1:17 am Post subject: |
Gammaboy wrote: |
brian wrote: |
Thanks Ben. Options are good. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
250GTLusso
Posted: Fri Mar 29, 2019 11:17 pm Post subject: |
Gents, the beauty of METAL RESCUE is that is NOT an Acid. And therefore does NOT attack the base metal of the tank. Try it. You will be amazed. _________________ 1978 Bimota SB2 00046
