Posted: Thu Sep 29, 2016 6:24 pm Post subject: |
| I have heard Maxton have done a DB6 for someone in the UK so have base settings. If you wanted to use them they are reasonably local to me so could get delivered to me and I would forward them on to you in US. |
quikduk
Posted: Fri Sep 30, 2016 8:02 am Post subject: |
That would be greatly appreciated. Thanks!  |
quikduk
Posted: Fri Sep 30, 2016 4:25 pm Post subject: New to Me DB6 |
OK. I finally fixed my Photobucket account and got some pics ready. I thought they were smaller images but...sorry.
The 2007 DB6:
Coming home on the night of purchase.
First maiden ride through Crestline, Arrowhead and Big Bear, CA.
quikduk
Posted: Fri Sep 30, 2016 4:28 pm Post subject: what the DB6 replaced...sniff sniff |
...and what the DB6 replaced...sniff sniff
1993 750SS-CR:
I really miss that bike. It was sooo light and sooo quick. It was around 389lbs wet and the HP out of that little 750 was astonishing.  |
quikduk
Posted: Fri Sep 30, 2016 4:31 pm Post subject: 750SS info |
Here is what the 750SS had in/on it:
Engine:
- MotoStille high mount carbon silencers without packing
- Staintune big tube SS headers
- CR Axtell ported and polished heads
- Manley oversized valves
- VeeTwo high compression pistons
- VeeTwo high lift cams
- Custom ported Malossi short intake manifolds
- Tuned Keihin FCR 39mm flat slide carbs with custom dual throttle cable
- Lightened flywheel
- Gelled battery
- Relocated oil cooler (above front cylinder valve cover)
- Upgraded wattage stator and wiring
- 15/41 final drive gearing with AFAM sprockets and gold chain
- Ducati Performance billet aluminum oil fill cap/plug
Body/Frame:
- Shaved fairing mirror stalks
- Zero Gravity windscreen
- Pro Italia titanium high mount exhaust hangers (painted to match platinum colored frame)
- Pro Italia GP billet aluminum rear-sets
- Pro Italia underslung billet aluminum rear caliper hanger and stay
- Pro Italia billet aluminum license plate frame
- Pro Italia billet aluminum side-stand bolt and auto-retract defeat plate.
- Custom rear fender chop with relocated mini turn signals
- Color matched seat cowl
- Ducati Performance front and rear carbon fiber fenders
- Ducati Performance carbon fiber air filter deflector plate
- Ducati Performance billet aluminum tank vent valve
- Custom Corse clip-ons
- Superlight swing-arm conversion with billet steel F1 pivot
- Complete Race-Tech Gold Valve for front fork with progressive springs
- Complete Race-Tech Gold Valve for rear shock with progressive spring
- Braking full-floating 320mm front rotor with SS lines and updated caliper
- Braking rear rotor with SS line
- CRG adjustable levers
- CRG Lane-Splitter mirrors
- 80/100W halogen headlight bulb
...sigh...  |
quikduk
Posted: Fri Sep 30, 2016 4:36 pm Post subject: |
BTW, you guys here that are restoring some of these Bimotas do an outstanding job!!! There aren't many of us (Ducatisti and Bimotasti) that would attempt such work...and most of you guys have fairly cramped garages (sheds?) to work within.
My garage is only a 3-car (with one car in it, two motorcycles, a bunch of tools and equipment...and a whole lot of the kids junk. My BIL has a 30'x60' metal building to "play" in. |
