Posted: Wed Mar 03, 2021 12:41 am Post subject: |
| Why not fit the bandit larger disc?..you say you need a new caliper hanger....so make one to fit the 240 disc? |
Anders
Posted: Wed Mar 03, 2021 7:53 am Post subject: |
| 2bims wrote: |
I interpreted it as he has to make a new caliper hanger due to the bigger Bandit disc... Hence my suggestion, as it is easier to make a new disk than a caplier hanger (provided you have access to the right tools). _________________ Anders
bb1, Stark Varg EX, Ducati Mille S2, Guzzi / Watsonian, Morini Corsaro 125, EC200, RD350YPVS etc |
ANGRY ANIMAL
Joined: 23 May 2020 Posts: 9 Location: NORTHWEST ``UK
Posted: Mon Jul 12, 2021 9:44 pm Post subject: |
Thanks for all your suggestions, i have got my frame back now now, started to build it up, front wheel now a marchesini from a Laverda ghost, rear GSXR1100 5.5 wheel disc machined to suit now on with the chain run wheel need chain aligned and then machine spacers for both sides, the brake plate will now be the problem as it needs to be a lot further over with the GSXR wheel. The original wheels must of been narrow across the hub.
This bike is a proper jigsaw does any body have photos's of were the thermostat fits and routing of hoses i have seen some but not really showing enough and i dont have all the hoses. can the filler cap be loose on the frame as there is no bracket.
cheers
Ian |
