Brembo disc thickness
Goto page Previous  1, 2, 3
PostPosted: Wed Sep 21, 2011 10:37 am    Post subject: Reply with quote
Yeah they rattle a bit.
PostPosted: Wed Sep 21, 2011 10:41 am    Post subject: Reply with quote
How 'loose' should the floating discs be? Mine are quite loose, is this normal. They don't move radially but they do move side to side. The bushes between the disc and the hub turn quite freely.
Yep I'm with Oily at that, yours sound spot on, side to side but no radial movement, designed to allow better centring of the disc to the pads/pistons, sounds like a pocket of change when you're pushing the bike, catches lots of folk off guard
PostPosted: Wed Sep 21, 2011 10:51 am    Post subject: Reply with quote
You're dead right there. When the bike first arrived and i pushed it into the carport, i thought something was dragging or catching.
PostPosted: Wed Sep 21, 2011 11:26 am    Post subject: Reply with quote
You'd love a DB2, rattly dry clutch, full floater front discs and mechanical valves on an "L" twin, sounds like your entire tool set has been tipped into the washer and put on High spin, and then theres the straight through zorsts and flat-slide valves and K&N ait filters, who needs ipods for a symphony of sounds?
PostPosted: Wed Sep 21, 2011 4:31 pm    Post subject: Reply with quote
The spring washers have got flattened so the disc moves around.
There was a thread about it on here somewhere ...
anyway they can be rebuilt with new spring washers so they don't rattle.
PostPosted: Wed Sep 21, 2011 5:40 pm    Post subject: Reply with quote
Would this be the aforementioned thread evil chuck?......
http://www.bimotaforum.co.uk/viewtopic.php?t=903&postdays=0&postorder=asc&start=15
Wink
Page 3 of 3
