SB8R leaking issue
Goto page Previous  1, 2, 3
PostPosted: Fri Feb 12, 2016 8:14 am    Post subject: Reply with quote
Tirefriar wrote:
. in many jurisdictions the cops can choose their own rides (within reason) as long as the markings are uniform with regulations.
Almost make's it worth being a motorcycle cop !!!! get to pick your own ride !!! Very Happy
PostPosted: Fri Feb 12, 2016 8:46 pm    Post subject: Reply with quote
Didn't Chips ride Kwakasuki's....... Laughing
PostPosted: Fri Feb 12, 2016 9:18 pm    Post subject: Reply with quote
Yes they were Kwaks. They had a pursuit gear that limited the speed because they didn't corner
PostPosted: Sat Feb 13, 2016 4:51 pm    Post subject: Reply with quote
LAPD (Los Angeles police Deparment) used to have their traffic cops on Moto Guzzi. LA Sheriffs used HD extensively. Now both departments are big Beemer fans. You are correct about the Highway Patrol being on Kawis.
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Wed Mar 02, 2016 7:34 am    Post subject: Reply with quote
During the delivery of my SB8R, left lower fairing was cracked. So, while the fairing is being repaired (should have it in a day or so) the SB8R is quietly sitting in the garage and... weeping oil. In about 2 weeks it dripped a very small puddle roughly an inch across. It is dripping from somewhere at the cooler in front. Not sure what it could be - seller went through the bike and replaced what he thought was leaking. Guessing need to tear down the fairings at the front....
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Thu Mar 03, 2016 12:26 am    Post subject: Reply with quote
Maybe a dodgy crush washer on one of the cooler banjo bolts (assuming it has banjo bolts?)
PostPosted: Thu Mar 03, 2016 12:28 am    Post subject: Reply with quote
I also had an aluminium cooler that was cracked at the thread where the banjo bolt screwed in. The banjo bolt must have been over tightened at some stage. It was very hard to identify where the leak was coming from
PostPosted: Thu Mar 03, 2016 2:20 am    Post subject: Reply with quote
I figure I'll start disassembly of the front fairings to track the source. In case the cooler is cracked, how expensive are these and are they still available?
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Thu Mar 03, 2016 8:39 am    Post subject: Reply with quote
Think the SB8R oil and water rads are standard TL ones, but not 100% sure.
I know the later 8K one's are different.
PostPosted: Thu Mar 03, 2016 2:10 pm    Post subject: Reply with quote
If you cant see where it's coming from clean the area and put some toilet paper on it (1 ply is enough). You should see where the leak is
sb8rs
PostPosted: Thu Mar 03, 2016 3:08 pm    Post subject: Radiators Reply with quote
The side radiators are KTM
The lower radiator is bespoke.
Armin has them in Germany about 600 Euro for the complete set I think???
135laura on EBay is Armin, I think he has them on there as well.
http://www.ebay.co.uk/itm/Bimota-SB8R-Wasserkuhler-komplett-3-teilig-/400790386568?hash=item5d50f7f788:g:hbEAAOSwDN1UQOza
PostPosted: Thu Mar 03, 2016 3:54 pm    Post subject: Re: Radiators Reply with quote
I don't read German and have yet to familiarize myself with the SB8 but these appear to be coolant radiators rather than oil.
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
sb8rs
PostPosted: Thu Mar 03, 2016 6:31 pm    Post subject: Reply with quote
sorry, talking about water radiators.
But please note as the lower does something leak.
PostPosted: Thu Mar 03, 2016 6:45 pm    Post subject: Reply with quote
Maybe worth to buy it and keep it on the shelf for that "just in case" moment. That approach always worked when I had my Alfas...
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Page 3 of 3
