SB6 x Japan now lives in Kiwiland
Goto page Previous  1, 2, 3 ... 23, 24, 25, 26  Next
Hursty
PostPosted: Wed Jun 18, 2014 1:50 am    Post subject: Reply with quote
Yeah Brian needs a polish Wink
You can hardly see Vince's it's so shiny Laughing
Yes my fuses are 20 15 15 10 20 so I guess the first 20 might have been to try and stop the fuses popping by a previous owner Confused
Hursty from kiwi land Smile
PostPosted: Thu Jun 19, 2014 4:40 pm    Post subject: Reply with quote
I don’t have much dust it's always raining… Wink
I guess I have a 15 amp too much. Confused
vince
Hursty
PostPosted: Fri Jun 27, 2014 1:45 am    Post subject: Reply with quote
So many days
And nights
Have passed since I dropped my bike off with my mechanic Rolling Eyes
Finally he has stopped rebuilding his race bike and started on mine Very Happy
Because I am fitting new brake pads I have decided to change the fluids
As they are looking pretty yuk Embarassed
and as often happens in the workshop it has been suggested that I replace the front brake lines so that has been added to the list as they are not how he (who knows) would have them.
Air filter is looking a bit grubby after 5000ks
The pipe is now off here is a better pic of the split on the weld that needs fixing.
And the leaking header hose turns out to be the rubber seal on the radiator cap not sealing properly, I believe these are a hard to source part? (especially in NZ ) so we will attempt to replace the rubber Surprised
So hopefully over the next week things will progress and no more surprises will appear Wink
PostPosted: Fri Jun 27, 2014 2:22 pm    Post subject: Reply with quote
It's a good idea to change the brake lines. Finally found the water leak, that's good Smile
PostPosted: Fri Jun 27, 2014 8:31 pm    Post subject: Reply with quote
Your radiator cap looks different from mine, ….. Not only mine is more shiny but the centre of the cap is different.
vince
PostPosted: Sat Jul 05, 2014 12:37 pm    Post subject: Reply with quote
Hi Hursty, some progress with the Bim Question
vince
Hursty
PostPosted: Wed Jul 09, 2014 3:00 am    Post subject: Reply with quote
Its wet and windy down here at the moment so no real rush
but my new Brembo pads have arrived, this is what they recommended any body used these?
Apart from that we have measured up for the new front brake lines
So the body work is all clean sitting in my garage and the rest is still on the mechanics bench Sad
I was looking at the pics of evil chickens clutch and noticed mine is different so must have been modified at some point Confused
Current thinking is that he will replace the leaking radiator cap and neck with a GSXR1000 item Rolling Eyes
PostPosted: Fri Jul 11, 2014 9:27 pm    Post subject: Reply with quote
When it is finished pics please.
Maybe a modification for the future.
vince
PostPosted: Sat Jul 12, 2014 1:12 am    Post subject: Reply with quote
Doubt you need to do the rear pads
Not sure what's in my front calipers
PostPosted: Sat Jul 12, 2014 1:35 am    Post subject: Reply with quote
My rear pads chatter and squeal when they get hot. Don't use the rear much anyway.
PostPosted: Sat Jul 12, 2014 8:20 pm    Post subject: Reply with quote
Hi Hursty,
I use Brembo pads but if they carbon ceramic I don’t know.
vince
Hursty
PostPosted: Tue Jul 22, 2014 2:14 am    Post subject: Reply with quote
So out with the old lines
And in with the new Very Happy
Rear pads were gone
but the fronts had a bit left in them but changed them anyway Wink
Progress is slow but its cold here now so plenty of time
Smile
Hursty
PostPosted: Sun Aug 03, 2014 11:22 am    Post subject: Reply with quote
Picked up a new front tyre before I went away on business and the matching rear should have been delivered by now Very Happy
Decided that the best fix for the old radiator cap is to get the radiator neck re made with a standard cap as no one could supply one (just like everywhere else in the world) But I did try and try and try.....
So the new one should be ready this week and I can move on with the work.
PostPosted: Sun Aug 03, 2014 11:26 pm    Post subject: Reply with quote
I'm running Michilin Power 3's on my sb6 at the moment and find them quite good. My bike had a 120-60-17 on the front so i replaced it with the same... I see yours is a 120-70-17.
PostPosted: Mon Aug 04, 2014 1:06 pm    Post subject: Reply with quote
I have a 120-70-17 Supercorsa Diablo ... you need to space the mudguard a bit. In fact I need to sort that out a bit more after I did a track day I couldn't pull the bike backwards because the tyre jammed on the mudguard. Once I rode it back to the hotel it was fine Question
Page 24 of 26
