Posted: Thu Jun 07, 2012 7:20 am Post subject: |
On a good note, the Mrs and the R1 are getting back on the mend
Sorry to heat that your biking interest has wained as of late. Hopefully as you are back on here from time to time your interest and faith in biking can be restored somewhat. Theres always frustrations with bikes and accidents can stall or stop some folk, but hopefully you can both get through that and come out the other side, little by little mate, all the best to Mrs Desmo for a safe and full recovery, I'll be keeping my fingers crossed. Oh and what the heck is "magnafluxing" before I google it |
Desmo_Demon
Posted: Thu Jun 07, 2012 8:18 am Post subject: |
2bims wrote: |
My understanding is that it's a way to check for cracks that are so small that you can't see them with the naked eye. The method I am most used to hearing about is running a polar current through the metal part and then using a ferrous dye of some sort that will concentrate and follow a crack in the metal. My father actually gave me a kit that uses a metal dust that you sprinkle onto the part with the current going through it, and if there is a crack, the dust will accumulate on top of it.
I'd hate you to put all this work into the bike and then have a crack that already exists get larger and make you tear the bike apart, again. _________________ Look for my books...
"If I Wrap It Tight Enough"
Posted: Thu Jun 07, 2012 9:02 am Post subject: |
Cheers Desmo for the info. Some time back I bought a spare set of brembo discs for the DB2 (fronts). When they arrived they were a little rusty, no great surprise being cast iron, but a good thickness and straight and true, so I thought I'd clean them up a bit and oil them before putting into storage.
All was going well until there seemed to be some small cracks eminating from the drilled holes of the discs, I used the "macro" close up facility on my high res digital camera, then uploaded onto computer and blew them up, turns negligible splinters into the Grand Canyon, quite illuminating. Fortunately Nice German man was very apologetic and gave full refund
And now for the close up
Desmo_Demon
Posted: Thu Jun 07, 2012 7:23 pm Post subject: |
2bims wrote: |
All was going well until there seemed to be some small cracks eminating from the drilled holes of the discs, |
I had issues with a bad master cylinder AND a bad caliper on my Harley at about 95k miles. With two components bad, but not total failures, it took a while to troubleshoot it. I wound up destroying two rotors as the brakes were dragging and the heat was cuasing cracks in the same location as those Brembos. _________________ Look for my books...
Posted: Tue Jun 12, 2012 11:04 pm Post subject: |
Well it was another dry and bright night and I'm away a bit in the upcoming future, so went for a last dry fit of all the bodyparts and Zorsts before final strip and away to powder coaters and painters
Getting a bit more into it now that the stripping of rusty and dirty/cruddy parts is over, its nice to be working with clean fresh new bolts and refurbished parts
Going to be doing the final rubdown/filling/sanding/reprofiling whilst the parts are on the bike as its a lot easier than loose panels and parts, tank temporary fit, it needs to move back an inch or so to meet up with the seat unit properly
Also note that I had to cable tie the end can to line and level as my exisiting hanger brackets are too long for the right line and level, so back on the hunt for new shorter brackets
Some serious trimming of the rear mudguard/number plate holder is needed, just waiting for the rear light unit to arrive so that I can dry fit that and see how high I can fix the number plate and then trim and cut to suit, or I just may fabricate an ally hanger for the plate and indicators
Thats all for now, hopefully get some time next week for a half day strip down and drop engine, forks, swinging arm and shock then disperse to the parts to the four corners of Northern Counties for paint/powder coat/polish
looking forward to collecting bits and final assembly in the dining room |
Posted: Wed Jun 13, 2012 9:06 am Post subject: |
What that really needs Steve is a nice set of wheels !! |
Posted: Sun Jun 24, 2012 8:11 pm Post subject: |
Well not much new with the Duc, finally got round to filing new panel edges to fit profile etc and final prep and wet and dry to the new bodywork to remove mould markings etc, so that the bodywork can not all come off and go to the painters,
Marked and set out in masking tape the new line for the cut down rear guard, keeping the underseat unit as is saves all the road crud from getting stuck up around the electrics etc
Have to also cut out the indicator mounts from the rear guard so that they can be reattached to the cut down section so that they fit with the correct splay and sit straight
Rear of guard will be cut to the underside of a shorty number plate
Front bikini section given final wet and dry and profiling prior to the paintshop
Chose the rear seat unit that has a removable bump stop for my "butties and pork pie"
I've even managed to loosen or remove all 18 disc bolts with only the need for an impact driver on one to loosen! A first for a Doocati and italian steel. And to think I actually bought appropriate chisels in anticpation of having to use them
Have several days off next week so it will be finally drop the engine time, and bodywork off to paintshop and frame, headlight assembly, crankcases and clip ons and headstock off to be sandblasted and powder coated together with wheels. Real progress to be made in the next 2-3 weeks...must be time to be looking for another project... |
Posted: Sun Jun 24, 2012 8:17 pm Post subject: |
Whilst looking for your next project, see if you can make it a Bimota _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Jun 24, 2012 8:33 pm Post subject: |
Its on the cards Nice to find someone else that doesn't care about the football |
Mike Jennings
Posted: Sun Jun 24, 2012 8:40 pm Post subject: |
Football....what football?
MikeJ. |
Posted: Sun Jun 24, 2012 8:48 pm Post subject: |
It bores me so much, I don't even watch the word cup if England is playing nobby stiles and bobby Charlton _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Jun 24, 2012 9:22 pm Post subject: |
oily wrote: |
It bores me so much, I don't even watch the word cup if England is playing nobby stiles and bobby Charlton |
Ditto
I hope they go through though, as it gives me 2 guaranteed hours of traffic free roads to ride on, sheer bliss, followed by more free time as people have been drinking as well |
Posted: Mon Jun 25, 2012 7:13 am Post subject: |
another advantage of living in Spain - they tend to play more often than the Brits in these tournaments _________________ Now - SB6R, GSX1400, KTM 990 SuperDuke
It was like that when I got here |
Posted: Mon Jun 25, 2012 8:33 am Post subject: |
Yeh, go on , rub it in, fortunately most bikers I know don't give a monkeys chuff about Football (myself included) seems to be part of the make-up of bikers support football or ride bikes, easy decision for me |
Posted: Mon Jun 25, 2012 8:57 am Post subject: |
It's the difference between brain cells and no brain cells.
Be fleeced an extortionate amount of money to WATCH a vastly overpaid socially inept actor fall over and pretend to be hurt.
OR
Go out and do something for yourself which doesn't involve being a voyeur and watching other people.......well, unless they're fit and wearing mini skirts.....
the birds that is _________________ SB6 mk1 (project mega light, big bore)
